[07-03-2010] PDAVIET - I8000 WM6.5 ROM (21895.5.0.90) - SB08
Sonblack
Super V.I.P
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.21895 Build 21895.5.0.90 PV
Lời cám ơn - Many thanks:
Admin Kawaguchi (so much for his tools)
Manager PhamQuang (so much)
SM BatKid (so much)
Adv Mod TranMinhMan (so much)
Adv Mod NhatToai (so much)
SVip Tom_codon (so much)
Member huyentrangallery (from Samsung, support I8000 for cooking)
Thông tin ROM - ROM Information:
Basic ROM: PDA_I8000NXXJB1_HW_40
Language: Only WWE
Pagepool: 8MB
Version: I8000.21895.JB1.SB08
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- Core 5.2.21895 Build 21895.5.0.90
- .NET Compact Framework Version 3.5.9198.00
- Windows Media Player 10.3 Build 21895
- Office Mobile (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile)
- FlashLight
- SRS WOW HD for OMNIA II
- Soft Reset (Written by Sonblack)
- VnKeyb v2.2.0 by ntd (Skin from hanoiwap, included Set Keyb in English - Thanks Super Mod Tmap)
- Opera Mobile 10 beta2 (please do not complain about this)
- Không hiển thị Popup của Mortscrip - No display Mortscript popup (Thanks Admin Kawaguchi)
- Java_JblendPackage_2_1_2_1_20090429_2_1_R6 from Topaz II
- Các ứng dụng cần có của PPC như: PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... với các version mới nhất
Basic applications for PPC such as
PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... with their newest versions.
- Loại bỏ nhiều ứng dụng không cần thiết mà tôi không thích! :D
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor, Application Store, Communities (Share Pix), Connected Home, Midomi, Task Switcher, SPlugin Favorites, Google Maps, Smart Memo, Smart Reader, Smart Sync, Task Switcher, Youtube, My Files, Adobe Reader, Opera Mobile, Java,...
Removed more unnecessary utilities which I don't like! (see above list)
Ai không thích icon nhỏ của Start Menu có thể làm như sau để xoá toàn bộ Registry dưới đây và Reset
Anybody don't like small icons of Start Menu can do as follows in order to delete all following Registry and Reset
[HKEY_LOCAL_MACHINE\Security\Shell\StartMenu]
"CustomGridForm"="StartMenu_Sonblack"
Link đã có sẵn - The links are available now
DOWNLOAD I8000 ROM 21895
I8000 ROM JB1 21895 - PART 1
I8000 ROM JB1 21895 - PART 2
Password for uncompress: Sonblack
Chúc vui!
Enjoy it!
Sonblack
i knew u were on to something, thanks a lot :)
p.s. is there anyway that u can pack a cab for MSN weather and MSN money please? they r kinda handy, thanks again.
The ROM is being uploaded to multiupload.com. Please wait... :D
The links are available now...
i have installed this ROM, sometimes it freez after i close file explorer,need to remove battery to restart, dont know why. other than that, everything is fine.
Hehehe, mới đi du lịch về lại có ROM up, sao mà cùng 1 lc ra nhiều ROM thế, up thui , Thanks anh Sơn nhiều.\-/
On my I8000, no case likes yours! :D Anybody here?
ya, i know. have never had any problems with ur ROMs. that is why its so strange, i'll try to find the problem, maybe one of my apps. thanks.
p.s. would u please make CABs for MSN weather and MSN money? thanks
e thấy cái X-hook rất hay, muốn chuyển chương trình đang chạy chỉ cần nhấn vào biểu tượng, còn bình thường phải vaof Task manager ròi nhấn đúp mới được
mà sau bản SB05 thfi k còn nữa
Chín ngưởi mười ý vì vậy với X-Hook các bạn có thể tự cài mà cũng không sợ tốn chỗ. Nói chung ROM chỉ là cơ bản, còn lại là các bạn, đừng đòi hỏi quá nhiều! :D
vâng e có hỏi về cái X-hook này rồi mà k ai cho file cài hết
bác Son cho e xin với ạ, e cảm ơn bác
Tuyệt quá, sau Tết đợi mãi mới thấy bác Sonblack tái xuất giang hồ, lại có cả link rapid nữa, thanks bác Sơn nhiều
Sắp có tool Check new ROM, mọi người đỡ phải vất vả nữa :D
Check new rom trực tiếp từ điện thoại nhé! Chú em làm sớm sớm đi để anh còn đưa vào ROM cho boà con phá chơi rồi bị lừa có new rom mà link thì rom cũ mềm hén! :)) Kiểm tra version mới qua GPRS hoặc Wifi mà lị! :D
Cám ơn Admin Kawaguchi đã hỗ trợ Sonblack.
The next ROM will have the new tool for checking new rom version directly from your device through GPRS or Wifi. You can check before entering the forum. :D
Thanks Admin Kawaguchi for supporting Sonblack.
Bác nào up chưa, bản này ấn X có thoát Message luon ko, bản SB07 mình bật chức năng X thoát nhưng nó ko thoát hẳn ko biết bản này đã sửa đc lỗi đó chưa hic
