Audio Concise Oxford English Dictionary and Thesaurus (Update v2.0)
dungeasy
link ne : http://www.mediafire.com/?zwezgzi4h1h
3 in 1: the Concise Oxford English Dictionary
and Concise Oxford Thesaurus with Audio
This value software pack consists of the most popular dictionary worldwide - the Concise Oxford English Dictionary and the Concise Oxford Thesaurus. The Concise English Dictionary is noted for its clear, concise definitions as well as its comprehensive and authoritative coverage of the vocabulary of the English-speaking world. The Thesaurus is ideal for helping you pinpoint exactly the right word, whether you are writing a letter, preparing a report, composing an essay, writing creatively, or solving a crossword.
Increase Your Word Power
* Over 240,000 Words and Phrases
* Over 365,000 alternative and opposite words to make your writing or speach more interesting
* 60 000 high-quality audio recordings with British English pronunciations compiled and recorded by Oxford University Press. The sound files have been especially optimized for best audio quality and maximun data compression.
* Most essential front matter included - abbreviations, pronunciations, notes on the usage of synonyms
* Clear layout with each new section (phrases, derivatives, usage
notes, etymologies, wordbuilder) on new line
* In-text lists and tables
focusing on core study subjects
* Origin Section tracing the history of words
* Hundreds of lists, from alloys and artists to worms and wines
The dictionaries are powered by the MSDict technology especially
enhanced for iPhone and iPod with the following key benefits:
* No connection to the Internet required - you can use the dictionary on your iPhone or iPod touch without connecting to the Internet and with no additional charges
* Ability to change the font size in the word definitions- this option is available from the device Settings.
* Original format of the OXFORD wordlist
* Fast article scrolling
* Quick search of words while you type
* Hyperlinks between words and articles
* History to see the last 50 words you have looked up
What's new
NEW Features in version 2:
* Bookmarks - you can use the Bookmarks feature as a learning tool and create your own topics and wordlist
* Filters added to help you locate the word you are searching for:
* Fuzzy filter- used when you are not sure of the correct spelling of a word
* Keyword- used to locate the instances of a key word within other compound words
* Wild card - "?" and "*" replace a letter and group of letters in words .
làm sao để cài vào iphone đây bạn ơi???
Nếu là App thì dùng WinSCP Copy vào máy, nếu là File IPA thì nhấn đúp vào File rồi kết nối iPhone với iTunes sau đó bấm Sync là được!
