Audio DSP & EQ plugin v.1.1-Hiệu ứng âm thanh cho PM phát nhạc!!!
BuuPhucCT
Well-Known Member
Đây là PM hỗ trợ thêm các hiệu ứng âm thanh và EQ cho PM chơi nhạc mặc định của Android và PM chơi nhạc của HTC giúp nâng cao chất lượng âm nhạc vốn khá nghèo nàn của Android.
TÍNH NĂNG:
• 10 Band Graphic Equalizer
• Audio Stereo Effects
• Cross-fading
Fancy an equalizer and audio effects but don't want to switch from the default media player? If so then this is for you.
Please Note:
• This is sort of a hackish improvisation over Android's default music applications, so may not work perfectly on every device.
• The volume buttons will only adjust the music volume if you are inside the Audio DSP Application. So if you need to adjust the volume simply open the app then you'll be able to use your volume buttons.
Supported Media Players:
• HTC Default Media Player
• Android Default Player
Formats Supported:
• MP3
• OGG Files
OS Versions Supported:
• Android 2.1
• Android 2.2
**May not perform well on slower devices**
Free Version Features:
• Bass & Treble Controls
• Equalizer (Resets after ever fourth song played)
Upgrade to unlock:
• Cross-fading
Thank you for supporting our application. Please feel free to send us your feedback.
Side Note:
Be sure to check out our Live wallpapers to add some live music visualizations to your home screens.
http://www.mediafire.com/?y9zbehg8dnwsf7f
