azRemote - Biến iPhone thành Remote TV
viphp1995
azRemote
itunes
This app is designed for both iPhone and iPad
$2.99
Category: Utilities
Updated: Feb 26, 2012
Version: 1.6
Language: English
Seller: Octaval Ventures S.L.
© octaval
Rated 4+
Requirements: Compatible with iPhone, iPod touch, and iPad.Requires iOS 3.1 or later
Tóm tắt:
AZRemote cho phép bạn kiểm soát tất cả các chức năng của vệ tinh / truyền hình / cáp set-top-box từ thiết bị iOS của bạn. azRemote tương thích với HD AZBox Elite,.....Cài đặt cấu hình địa chỉ IP của hộp set-top của bạn vào các thiết lập của AZRemote.
Description
AZRemote lets you control all the functionalities of your satellite/tv/cable set-top-box from your iOS device. azRemote is compatible with the AZBox HD Elite, Premium and Premium+. Using AZRemote is as simple as configuring the IP address of your set-top-box into the settings of AZRemote. AZRemote uses the WiFi connection of your set-top-box to command it, so you will be able to control your set-top-box
from any place in your WiFi coverage range.
What's New in Version 1.6
Add access to configuration from within the app.
Enable rotation of the keyboard.
Fixed button feedback.
Change position of the keyboard to the right side of the screen in iPad portrait and landscape mode.
Access to support via email and web.
