AquaSta
Moderator
Battery Doctor Pro v5.4
Bạn đang mong chờ một ứng dụng pin đầy tính năng? Bạn có cần một ứng dụng giúp bạn tăng tuổi thọ pin nhất? Battery Doctor Pro chính là cái bạn cần đấy
Battery Doctor Pro cung cấp nhiều hơn các thông tin về pin của bạn. Thật dễ dàng để hoàn thành một Vòng Sạc Đầy (Full Cycle Charge) với ứng dụng này
Ứng dụng có 6 mục tính năng là
►Battery Status◄
Each day, this program will display the remaining usage time (correct to the minute) based upon your specific device and available battery capacity; your intended use of it (16 specific conditions are provided.) You also can customize the display of items. Our battery data are more accurate than other apps.
►Full Cycle Charge◄
Let your battery RUN DOWN to at least 20%, then LAUNCH Battery Doctor app from home screen. and PLUG in the charger cable, Battery Doctor will do the rest for you.
►Build theme with any photo◄
You can make your own theme with any photo, such as a photo of your family, friends, pet, cat, team LOGO, company LOGO or art photo, etc. If these photos are in our album, you can easily import, zoom and place them through the program, and create very beautiful battery icon theme. (Theme only available at App inside)
►Charge Log◄
The log can track your device’s charge time, type and remaining battery capacity.
►Battery Tips◄
A lot of information on the proper use of your battery is provided here, and the battery life may be extended by adjusting your settings.
►Battery Health◄
The iPhone battery is properly maintained, after 400 charge-discharge cycles, 80% of the original battery recharge capacity can be retained.
What's new in Version 5.4
► FREE UPGRADE (5) ◄
1. Improve the 1% battery increaments
2. Minor bugs were fixed
3. Add more themes
4. Improve the translations
5. Improve the Full Cycle Charge
This upgrade is totally free to all users! Want us to keep the free updates coming? ratings and nice comments allow us to keep providing our existing users with new features. Did you know you can rate us again for each version?
Ứng dụng hỗ trợ ngôn ngữ tiếng Việt, mình bỏ hết các ngôn ngữ chỉ để lại tiếng Việt mặc định (iPhone để tiếng anh thì ứng dụng vẫn sử dụng tiếng Việt)
Download: http://www.mediafire.com/?q3v4tmczf0ivcjv
