Battery Monitor Widget Pro v1.0 RC1-PM hiển thị thông tin pin cực pro
BuuPhucCT
Well-Known Member
Đây là PM cực kỳ hữu ích vì nó giúp bạn biết được chính xác dung lượng của pin, charge/discharge (mA & mW), voltage and nhiệt độ của pin.
THÔNG TIN
Shows %, temperature and mA in status bar using external packages.
Shows and saves history, shows scrollable/zoomable graphics, long-press for full-screen.
Triggers alarm base on battery full/charged/half or voltage and temperature levels.
To get battery % in status bar, go to settings, notification and alarms then select icon type 'external package'.
Lowest battery consumption on the market! Collects more data for less CPU usage! Check screenshot and try it for yourself! 10000+ happy users
If you want only the notification icons/alarms, you can disable the graphics and history to reduce consumption even more!
Recommended by Motorola support team!
Not all phones supported:
- mA data may be desynchronized and/or estimated
- Some data may not be reported at all
Recent changes:
1.0 RC1:
Phone settings replace 12-hour option
Widget preferences shown when single active widget
(click on a widget (to open app) to access its settings)
Reduced overall package size and CPU usage
Fix clear history requires exiting the application
Fix dead widget
DOWNLOAD
http://www.mediafire.com/?ezpy2hn3jd212nx
