Bluetooth PC Remote Control 4.0
bete_seeya
Bluetooth Remote Control is a true universal remote control that lets the user adds or modify the controlled programs. Customize simple keymaps or for full control over the UI write your own Java and VB scripts.
See your Power Point slides directly in the phone, browse/play the songs in ITune and Media player and much more...
Bluetooth Remote Control supports the following programs: Support for additional programs can easily be added with simple keymaps, VB or Java scripts (Script Guide).
iTunes
Shows song name, artist & track time and UI objects
Browse playlists, songs, artist, album and composers
Search for songs
Rank tracks
Toggle shuffle
Repeat track or library
Play/pause, rewind, fast forward, change volume, previous/next track
Mute
PowerPoint
Shows next slide and slide notes
Shows actual slides
Play/stop presentation, previous/next slide
Load recently used file
Browse/Goto all/any slide
Presentation time
Scroll slide notes
Vibrate when time expires
WinAMP
Search for song and artists
Toggle shuffle mode
Change volume
UI objects
Toggle repeat mode
Windows Media Player
Browse playlists and artists
Rank tracks
Toggle shuffle
Mute
Mouse mode
Full support for controlling the PC mouse
See the computer desktop on the phone
Zoom in and out of the desktop
B&W colors for faster response time
Enter text
File Browser
Allows launching of files
System
Change system volume
Start screensaver
Lock workstation
Shutdown Windows
Start screensaver
Here are some key features of "Bluetooth Remote Control":
Control iTunes, PowerPoint, Mouse, WinAMP, Windows Media Player and much more
Create your own applications via Keymaps or VB and JScripts
Supports most Bluetooth enabled phones and all Bluetooth PC solutions
No Bluetooth setup! Just connect from your phone
See the actual desktop in your phone
Xem thêm tại http://www.blueshareware.com/
Link
http://w17.easy-share.com/1701184675.html
http://rapidshare.com/files/136335030/Bluetooth_Remote_Control_v.4.0_www.softarchive.net.rar
Mong bạn ý copy bài ở đâu thì có thể dịch sang tiếng Việt được ko ạ. Để thế kia chả hiểu mô tê chi hết trơn
mình dịch dùm bạn nha !
Bluetooth Remote Control là một điều khiển từ xa thật phổ cho phép người dùng thêm hoặc sửa đổi các chương trình kiểm soát. Keymaps hoặc tùy chỉnh đơn giản cho toàn kiểm soát đối với UI viết của riêng bạn Java và VB script.
Bluetooth Remote Control hỗ trợ các chương trình sau: Hỗ trợ bổ sung cho các chương trình có thể dễ dàng được bổ sung đơn giản với keymaps, VB hay Java script (Script Hướng dẫn).
Hãy xem các trang trình bày trực tiếp Power Point trong điện thoại, trình duyệt / chơi các bài hát trong ITune Truyền thông và máy nghe nhạc và nhiều hơn nữa ...
iTunes
Hiển thị tên bài hát, nghệ sĩ & thời gian và theo dõi các đối tượng UI
Tìm bài hát
Duyệt qua danh sách nhạc, bài hát, nghệ sĩ, album và Composers
Đánh giá theo dõi
Toggle shuffle
Lặp lại theo dõi hoặc thư viện
Play / tạm dừng, rewind, nhanh chóng chuyển tiếp, thay đổi khối lượng, trước / kế tiếp theo dõi
Tắt tiếng
PowerPoint
Truyền hình thực tế slide
Truyền động và động tiếp theo ghi chú
Nghe / ngưng trình bày, trước / kế tiếp động
Tải tập tin được sử dụng trong thời gian gần đây
Trình duyệt / Goto tất cả các / bất kỳ động
Trình bày thời gian
Di chuyển động ghi chú
Rung khi hết hạn thời gian
WinAMP
Tìm bài hát và nghệ sĩ
Chuyển chế độ chế độ shuffle
Thay đổi khối lượng
UI các đối tượng
Chuyển chế độ lặp lại chế độ
Đánh giá theo dõi
Duyệt qua danh sách nhạc và các nghệ sĩ
Toggle shuffle
Tắt tiếng
Chuột chế độ
Hỗ trợ đầy đủ các kiểm tra, kiểm soát con chuột máy tính
Phóng lớn trong và ngoài của máy tính để bàn
Xem các máy tính vào điện thoại
Nhập văn bản
B & W màu sắc cho thời gian phản hồi nhanh hơn
Cho phép các thương hiệu của các tập tin
Trình duyệt tập tin
Hệ thống
Thay đổi hệ thống âm lượng
Bắt đầu bảo vệ màn hình
Khóa máy trạm
Shutdown Windows
Dưới đây là một số tính năng của KKK "Bluetooth Remote Control":
Control iTunes, PowerPoint, Mouse, WinAMP, Windows Media Player và nhiều hơn nữa
Tạo các ứng dụng của riêng bạn thông qua Keymaps hoặc VB và JScripts
Bluetooth hỗ trợ hầu hết các điện thoại được kích hoạt Bluetooth và tất cả các giải pháp máy PC
Không có Bluetooth thiết lập! Chỉ cần kết nối từ điện thoại của bạn
Xem các máy tính để bàn thực sự trong điện thoại của bạn
