Call Guard (Block Calls/SMS) v2.6.1-PM chặn cuộc gọi cực tốt!!!
BuuPhucCT
Well-Known Member
Mình đã test rất nhiều soft chặn cuộc gọi nhưng mình thấy soft này là hay nhất với nhiều chọn lựa, chặn cuộc gọi cực nhanh và quan trọng là cách cài đặt khá đơn giản không quá rắc rối như một số PM tương tự khác.
Thông tin về PM:
*Important*
On some devices reported by our users an app called Caller ID or City ID (Verizon preloaded) might run into conflict with Call Guard. Please disable this app or any other app that might listen for incoming calls (if in doubt).
With Call Guard you can block incoming calls/sms (text messages) or outgoing calls.
Now with Full Pick up/Hang up mode(no voicemail,no notifications) support for all versions, (2.3 Gingerbread included)!The only app on the market which leaves no traces of the call, even on Gingerbread. All other supported OS versions work 100% as well!
Call Guard is the most affordable, advanced and feature rich call and sms blocking app on the market! Guaranteed!
Don't pay a monthly fee to have your wireless provider enable call blocking for you, with our small app you pay one time and receive the best app on the market for blocking call/sms!
Features:
✔ Stealth mode - hide the application icon, nobody will know the app is installed
✔ Three auto modes of operation - drop call (will send to voice mail if VM enabled or busy signal if no VM enabled), pick up/hang up mode (no voicemail, no busy signal, will LITERALLY PICK UP and then HANG UP) or muted (discret blocking without the other party knowing that they are being blocked, ringer set to mute) either via filter or general settings.
READ MANUAL FOR MORE INFORMATION!
✔ Block all calls, block hidden numbers, block calls from callers not in your contact list. Add white and black lists. Delete blocked calls from the log.
✔ Block outgoing calls - all outgoing, all from your contact list, all not in your contact list, block outgoing based on a black list. Ideal if you leave your device unattended, give it to someone else or have kids and do not want them to use your phone for outgoing calls.
✔ Block numbers by template (0180,0181etc.)
✔ Password protection for the app under settings, useful when you block outgoing calls.
✔ Block all incoming SMS (text messages), block unknown numbers or add a white or black list for SMS. No traces/logs are being left of blocked SMS/text messages in other messaging apps.
✔ Block SMS containing text (comma separated list of keywords)
✔ Use general settings or add filters for a specific day and/or time.
✔ Filters could be tailored by days of the week, time of the day (start/end hour) and you can also specify if the calls in the filter should be muted or dropped (send to voicemail or pick up/hang up, no voicemail).
✔ Reply with a predefined SMS for all the blocked incoming Calls or Text Messages (filter or general settings).
✔ Delete call log entry for blocked calls.
✔ Home Screen widget (On/Off toggle)
✔ Notification icon
✔ Customizable Notification for the missed calls (you can use a custom text like "update available" to hide the fact that a certain call/sms was blocked. (stealth and invisible blocked sms and calls)
✔ Keep an in app history for all blocked calls and text messages.
✔ Easy accesible statistics inside the app for all blocked events.
✔ Notification system for blocked calls/sms - normal notification, sound notification, led and vibration.
✔ Operational Manual and direct contact form for suggestions or questions.
Before contacting us:
- Make sure you have READ THE MANUAL.
- If you still have questions, use the form inside the app, include your device information (click yes) and add a screenshot of the filters/settings page or detailed explanation of the set up.
Emails in the form: "It's not working" will be ignored,sorry
IMPORTANT:
- LG Optimus 2.2 is not supported
Check out our other Apps
✔ Walk and Text (Texting while walking is dangerous - not any more!)
✔ Spoty (Location Reminder, Call Blocker, SMS Sender, Profile Changer)
✔ Battery Percentage Alarm Icon (See the Percentage of the Battery,
✔ Emergency (Panic Button, sending your location in a case of emergency)
✔ Amazon Free App of the Day Notifier
✔ Safe Drive (Block calls and SMS while driving)
✔ Hide Caller ID
✔ Total control (Shake2Call)
Recent changes:
Please start and enable the app after each update!
2.6
- Opt-out save log (no log of blocked events)
2.5
- opt out of Saving reply SMS
2.3
- Single notification option (under settings)
2.2
- Pick up/Hang up support for 2.3.x! No voicemail!
1.9
- General Calls/SMS Black and White lists
- General outgoing Calls Black and White lists
- enhanced blocking algorithm (without first ring)
- Block Incoming/Outgoing containing digits (comma separated multi list)
minh cai vao roi nhg khi thu thi botay ko chan dc so trong danh sach den ko hieu do loi gi nua hic. minh dung LG p999. xin V.I.P tro giup...?
Bạn nên dùng Root call blocker pro, chặn cực tốt. Các ứng dụng kiểu này đôi khi không tương thích với tất cả mọi loại máy.
Lần sau gửi bài tiếng Việt phải có dấu nhé bạn.
