CFW Firmware N97 v22.0.110 Hacked v5 by Pirates_Killer <So Hot>
nxhoang90
CFW N97 v22.0.110 Hacked v5 by Pirates_Killer <So Hot>
Vừa thấy trên Symbian Talk , mừng wá lôi về test thử, Anh em N97 nhào vô nào . Đây là info về FW , Tiếng Anh ,nhưng rất dễ hiễu AE chịu khó xem nhá.Hay ai mún xem info fw này Tiếng Việt thì kéo xuống #7 nha !
NOTE:
These are custom firmwares. Only use J.A.F. to flash your phone, using any other flasher like Phoenix will make your phone to be dead. Use this cfw at your own risk, it may brick your phone.
If you want Noob-friendly hacking, go HERE
ScreenShots
ALL LANGUAGES SUPPORTED
NOW PRESENT:
PIRATED v5 FINAL FOR N97 RM-505 v21.0.045, v21.0.102 and v22.01.110
WARNING!!!!!
1) Hard reset very needed to avoid conflict of homescreen and apps installed
2) Never restore your backup just setting backup..don't restore setting...
3) Format MMC is recommended or just delete E:\private E:\sys E:\system E:\resource E:\patches and F:\private F:\sys F:\system F:\resource F:\patches
CHANGELOGS FOR NOKIA N97 PIRATED VERSION 5
APPLICATION AND SETTINGS:-
THEMES
- Nseries 5 ( n97 mini -Gold original theme) by DhanuSaud
- Kayu 2.0 by IND190
- Horizon Black Lite by DhanuSaud
APPLICATIONS
- Rompatcher+ v2.3
InstallserverRP+ auto on
Open4allRP+ auto on
OpenCRoot auto on
- Autoinstaller v1.2
- Bestscreensnap v2 installed in C:
Image type: Jpeg - High Quality set automatically
Base file name: Pirate set automatically
Storage: Memory card set automatically
- Killme v1.36 installed in C:
- Xplore 1.45 with vista icons installed in C:
Using Vista icons mod
Show hidden files automatically
Show RAM Drives automatically
Show system files/folders automatically
Sort by: Extension automatically
Use system font automatically
- Vivaz Conversation edited icon
- Ramblow in Z:
Memory boost set to auto
30min idle it will cleanup
Follow theme background
- Bright Light Touch
- Nokia File Browser v4.5.2
- Pocket Sensor
- Timer Lite v1.1
FEATURED:-
- Remote Lock still enabled
- Voice Command still enabled
- Nokia OVI Welcome (My Nokia) Disabled
MODS
SYSTEM CACHING AND PERFORMANCE:-
- Running application will cache in E: for better performance
- RAM totally Optimise at startup
- Some Apps totally disabled on startup
- Increases system memory heap size
- Decreases application delay and close time taken by apps
- UI Acceleration (reduce lags in apps)
AUTO MAKE/COPY FOLDERS:-
- E:\thinkchange\c
- E:\thinkchange\e
- E:\Music
- E:\patches (auto copy patch)
PATCHES:-
- 2themes
Change for HS folder in 10207254 from Z: to C:
- Bluetooth Locker
Bluetooth cannot be enabled
- Deny New Installation
Cannot Install Any Apps
- Disable Default enhancement note
Delete enhancement note when connected
- DisableLogs
Log will be disabled
- DisableUSSDNotes
USSD note disabled
- Install Server RP+
Enable install all unsigned, all caps apps
- LCD Light ON
LCD light always ON
- LCD OFF Charge Complete
When charging completed, LCD turn off
- Long Multi Tap
Increase delay time for all keys (a little bug)
- NoBlankPassword
No more ***** shows
- Open4All RP+
Open dir of sys, private
- ReadCRoot
Make nokia file manager to view all files in C:roots
- Remove red LED
Red LED removed in camera
- Settings Deactivate
Unable to open settings in menu
- Short Multi Tap
Decrease delay time for all keys (a little bug)
- Switch Shutdown to Reboot
Power button will responsible for rebooting phone
- USB Data Disable
Disable USB connectivity
- 12 Month Call log
Call log will stay for 12months
- c2z4bin THUMB
mapping bin to C:
- Disable Profile switchNote
No more profile switch note
- Activate Bass Effects
Give BASS effect to musics ( dont know works or not )
PERSONALISATION:-
- Using S60 Busy Cirle Menu
- Shutdownscreen : S60
- Splashscreen : S60
- Bootscreen: S60 blinking by pirates_killer
- Shutdown image removed for faster shutdown
- Alarm snooze interval is set to 7min by default
- Light Intensity set to 50% light by default
- Theme Effects: Android Theme Effects In v5 by a1exyar, edited by grk007
INSTALLATION:-
- SwiPolicy changed which enable to install almost apps without installserver patch
- Remove annoying widget security during installation of sis, sisx
- Secure Widget Preinstall will not run on first startup, feel faster and ovi store will not work!!!
- Java permission is default to be more secure
SECURITY:-
- Automatic lock phone in 30 seconds by default
- Display light timeout set to 30 seconds by default
- Maximum automatic lock phone can be set up to 10 minutes
- Reenable remote locking after mistake in PiRaTeD v2
MENU AND SENSORS:-
- Tapping Mode added: shake to get phone silent/snooze alarm (off it at tapping control)
CONNECTIVITY AND BROWSER:-
- Nokia Default Internet Browser can go landscape with turning control OFF
- Download manager will be started on browser start-up to resume
- Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
- Nokia default file browser will open private, sys, C: root folder
- FOTA reserved spaces in C: deleted: gain 5MB
- Bookmark edited
MESSAGING, CONTACTS AND HIDDEN APPS:-
- Message to My Nokia will not send on startup
- Delivery reports set to on by default
- No. of message sent saved increase from 20 to 999 by default
- Ovi Contacts totally disabled
CAMERA:-
- Camera sound is disabled only and only if Warning Tone is OFF
- Camera will not leave in background after close it (SAVE RAM)
VOICE RECORDING AND VOLUME:-
- All automatically set to the highest quality
- Now you can record up to 12 Hours!!!!
- Internal speaker automatically set to maximum when calling
- Loudspeaker automatically set to normal 5/10
- Bootscreen volume slowed: Normal volume
- Voice recording during call fixed
MUSIC PLAYER AND GALLERY
- Put all songs file in E:\Music and F:\Music
- Music player only read E:\Music and F:\Music location
- Faster to refresh
- Gallery Improved to find files
SPECIAL LITTLE MODD By Varfolomey
With this mod N97 users can wake up device from stanby mode(activate display light) by touching the touch screen like in 5800,before that
you had to press any button,menu button for example to turn the display light on.so no need to press button anymore.
100% working
Bonus Ringtones
- Ovi Sound
- Ovi Nokia
- Tiger's roar
you can find them in profile settings
OVERVIEWS FOR NOKIA N97
- RAM after reboot: 60mb
- RAM after clean up: 57.52mb
- C: drive space after reboot: 59.2mb (the screenshots above show 54mb because i have installed ovi store in C)
- RAM experinces may different due to language in rofs2
MUST!!!!! READ THIS NOTICES BEFORE DOWNLOAD!!! IGNORING THIS, YOU GET NOTHING!!!!
1) Do hard reset before and after flashing
2) Remove E:\sys E:\system E:\resource E:\private E:\patches or FORMAT MMC before flashing
3) Please let your phone for 3 minutes until it ask you to reboot
Report : vừa test xong , tuyệt vời , hiệu ứng cực đẹp , AE check mau ^^
download về bạn sẽ được 1 file tên là "RM-505_22.0.110_C01_prd.rofs3.fpsx" , chép đè file này vào C:\Program Files\Nokia\Phoenix\Products\RM-505 sau đó dùng JAF Flash FW lại , bạn có thể tham khảo thêm các Flash FW = JAF ở trong 4 rum
flash ha?ngan' wa ih..hjx...onl bang dt,k co dau,thog cam...nhug se edit lai khi online bang lap
Giá mà có tiếng Việt, hjc, cái này đúng là cái mình cần, nhưng FW nên cần cụ thể trước khi flash....please translate to Vietnamese
Hỗ trợ Mọi Ngôn ngữ , an tâm mà Flash , nó có ghi cụ thể từng phần mà bạn , rất dễ hiễu , để mình dịch tạm cho bạn hiểu ngen
Tạm dịch như sau :
Ghi chú :
Đây là CFW , chỉ sử dụng JAF để flash , dùng các phần mềm khác như là Phoenix...,.. sẽ làm dead phone....
Chú ý này :
Phần này chủ yếu kêu bạn hạy Hardformat lại Fone , Mass store trước khi Flash
Themes :
Thêm 3 themes mới
Ứng dụng
Rompatcher <đầy đủ các patch>
Autoinstall 1.2
Best screensnap
X-plore 1.45
Ramblow
Tích hợp hội thoại vào Mess
File Browser
Pocket Sensor
Timer Lite
Một số đặc trưng :
Lock remote vẫn hoạt động
Voice command vẫn hoạt động
Lời chào ỡ Nokia Ovi sẽ bị Disable
Đây là phần MOD
bộ nhớ đệm và hiệu năng
Việc chạy ứng dụng sẽ đươc lưu trong bộ nhớ đệm E và mang lại hiệu năng tốt hơn
Tối ưu hóa ram khi khởi động
Một số App sẽ bị vô hiệu hóa khi khởi động
Tăng kích thước bộ nhớ heap
Giảm thời gian đóng mở các ứng dụng
Tăng tốc thực thi ứng dụng
Tự tạo và sao chép thư mục
Music thì cho vào E:\music
Patch thì cho vào E:\Patch
2 cái trên hok wan tâm :)) hình như là bạn bỏ những file sis,sisx ,...mún cài đặt vào 2 thư mục đó để sử dụng phần mềm auto install , tự động cài 1 loạt khỏi phải cài từng cái
1 số patch
-2 themes
-Thay đổi thư mục HS sang C
-khóa Bluetooth
-Từ chối việc cài đặt các ứng dụng mới
-blah blah .... phần này nói chung giới thiệu về các patch , cái nào k biết xài thì đừng apply , ^^
Tùy chỉnh giao diện
-sữ dụng Menu Busy Circle S60 < cái này hok biết dịch sao cho bạn hiểu , nói chung la nó thay cái cục tròn tròn nhỏ nhỏ khi bạn chạy ẫn ứng dụng nó hiện lên đó
-Thay Shutdown + Boot Sceen
-Alarm
-Độ sáng mặc định 50%
-Hiệu ứng themes mới , đẹp độc , xoay chuyễn tá lả :))
Phần này là cài đạt : cái này lười dịch , đọc chi cho mệt :))
Bảo mật :
Tự khóa phím mặc định trong 30s
Đèn màn hình tắt sau 30s
Thời gian tự khóa phím có thể tối đa là 10 phút
Kích hoạt khóa phím = Remote < chả hiểu :))>
Menu và bộ cảm biến
Cái này chả biết dịch sao , tạm hiểu là lắc để chuyễn sang im lặng
Kết nối và trình duyệt
-trình duyệt có thể tự xoay ngang nếu bạn tắt cảm biến chuyển động < hay nè >
-Thêm cái resume Download
-Gửi sis ,six ,jar ,..... wa bluetooth được lun
-trình duyệt file mặc định của máy có thể vào được private ,sis , root ,.... <hay nữa>
-ổ c có thêm 5mb <bik vậy dc rồi :)) >
-Chỉnh sửa bookmark
tin nhắn,danh bạ , và các ứng dụng ẩn :
-Thông báo của nokia sẽ k gừi khi khởi động
-báo gửi tin được thiết lập mặc định < có thể vào setting sms để tắt đi>
-Lưu tin gửi đến 299 tin
-Ovi contact bị vô hiệu hóa
Camera
-Thiết lập tự động để có chất lượng cao nhất < đại khái là chụp đẹp hơn =)) >
-Ghi âm đến 12 tiếng < khủng lun>
-Loa trong được thiết lập maximum khi gọi <nói chung là chỉnh sẵn volume khi gọi là max đó >
-Ghi âm giọng nói trong suốt cuộc gọi < chưa hiểu lắm , đang mò :)) >
Trình nge nhạc và Gallery
ở phần này chủ yếu là kêu bạn dặt nhạc trong E:\music và F:\music vì trình duyệt của máy chỉ nhận nhạc trong E:\music và F:\music thui , rùi tăng tốc làm mới danh sách nhạc nữa ....
Một số MOd nhỏ
cái này thì nó nói là giống như 5k8 khi bạn chạm vào màn hình thì sẽ sáng đèn thay vì bạn ấn nút
Thêm 1 số nhạc chuông mới
Cuối cùng là tồng quan
-Ram sau khi khởi động là 60mb
-Ram sau khi clean là 57,52 mb
-Ổ C trống 59.2 mb
Cuối cùng là phần chú ý trước và sau khi Flash
-hardformat toàn máy trước và sau khi up fw
-để fone trong 3 phút cho đến khi có thông báo khổi lại phone <cái này hình như nó chạy cái gì đó >
nói chung đây là 1 fw rất dáng để thử , mình test rùi , ok hết
Quá tuyệt vời, còn mong chờ gì hơn thế nữa, test thôi, mà pro test rùi ah? Chắc chắn phải hard reset ah? format cả ổ F nữa sao? thậm chí là hardreset sau khi flash xong nữa hả?
< nói chung đây là 1 fw rất dáng để thử , mình test rùi , ok hết >
Bạn nói là bạn test rồi hả ,ok không ?mà bạn sử dụng JAF để flash là bản nào bạn có thể cho mình link download được kg ?dùng Phoenix. để flash được kg ?
Tuyệt đối ko dùng Phoenix nha, dùng bản JAF này nè. Thực ra mình cũng đang gặp vấn đề lúc flash, nó yêu cầu
PRESS POWER ON
Searching for device...
nhựng ấn nút nguồn, máy lại bật lên, và nó báo searching for device...NOT FOUND
máy vẫn chạy bình thường quá trình flash thì dừng lại. chẳng test được.
Bạn cứ flash ở Normal mode , đừng chọn vào Dead USB , mình toàn flash em N97 = Normal , Dead usb hên xui lắm , mình đang xài CFW này , hiện giờ thì chưa có lỗi gì xảy ra cả , xài rất OK
Chết rồi, máy ko khởi động lên được, cho mình nick YM đi, khẩn cấp
Mình đang mò mẩm và up thử. do lần đầu nên còn chưa có nhiều kinh nghiệm.
Mình đang dùng win7 64bit, sau khi download bản JAF 1.98.66beta5 về thì ko mở chương trình lên được, tưởng là do chưa tương thích với win7 nên mình cho chạy compatible với Win XP SP3 cũng ko đc luôn >.<". Nó báo lỗi là "P-KEY dongle not detected. Please insert activated dongle". Lỗi này khắc phục như thế nào ạ? Thanks
giờ mình đã có pkey, khởi động chương trình giờ lại báo "can't load WinSCard.dll" là sao mấy bác nhỉ?! =.='
Nên down và làm theo hướng dẫn ở link bên trên mình đưa ý, yên tâm, mình vừa nghịch ngu Dead phone rùi, nhưng ko phải do fw này, mà do...gà
chào bạn Dương, cho fép mình hỏi bạn chạy JAF trên win nào vậy ạ? Sao mình làm hoài mà lỗi suốt ko chạy Jaf đc >.<'
Hack này khi hard reset không bị mất đúng không nhỉ? Để test thử xem sao.
Mình chỉ xài winxp thôi mà, mình J.A.F ngon lành rùi, nhờ chủ thớt hướng dẫn đó, dễ lắm, bạn phải add YM của chủ thớt vào, bạn ấy hướng dẫn và send cho mấy file bí truyền thì ổn ngay, lúc đầu mình cũng không làm được. có số điện thoại chủ thớt ở chữ kí đấy. Ráng lên, mình cfw thành công rùi, xài ok lắm, ko lỗi gì hết á
Bác chủ thớt có bí kíp gì up lên cho mọi người luôn đi, thấy flash có vẻ khó khăn hơn mấy hack trước nhỉ, mà có ai biết tại sao không hack được bằng phonix không nhỉ?
