[CFW]Nokia C5-00 CFW v2.0 by sam-RM-645-071.005
Eagle_eyes
Nokia C5-00 CFW v2.0 by sam-[RM-645-v071.005]
Hi Guys, I am again presenting an updated version of CFW for Nokia C5-00 users.
Please note RM number and version number to avoid confusions
Features
Phone memory hasbeen extended to 109 MB
Permanent Hack+Rompatcher with Auto
Java permission hacked
Default themes removed and 'Just black' is set to auto
Startup tone changed to that of Win7.
Startup animation,Shutdown animation and splashscreens are changed and shutdown tone added.
5 additional effects added to ROM and corresponding patches are available in Rompatcher+
4 additional menu views added- 3x5,3x3,2x3 and 4x4
system folders are visible in Filemanager.
Filemanager can send all type of files including protected,java,unsignd,etc.
Heap size modded
call and message logs are extended to 365 days
Realplayer settings changed
Menu features enhanced.You can move and rename anything.
gallery mod, enabled Quick gallery
Music player reads files only from E:\Music\
Press and hold of 0 key wil lead you to Phone Torch instead of Web.
alarm setings modded and snooze time changed to 3 minutes.
5800 audio codec added
browser cache moved to E
caller ID displays name
number
call and sms notifications turned ON
camera sound completely removed.
camera save RAM after closing it.
camera quality increased to 100%.
character encoding set to full support
FOTA disabled.
Annoyil Welcome SMS disabled and My nokia app removed.
keylock time and backlight time adjusted.
MMC icon turned ON
System Cache has been optimised.
recording quality increased.
prodcast removed from music player.
broken downloads are now resumable.
calling time is shown.
sent SMS is extended to 999
summery after call turned ON.
Theme effects ON by default
text size is set to small.
Default Theme effect is changed.
UI accelaration mod.
Mass storage is set as default in USB connection.
Video recording quality increased.
voice sensitivity changed to full.
writing speed is changed.
reject call with SMS turned OFF and Speeddial turned ON.
call volume changed to full
Following apps are already integrated:
    Romptacher+ Auto
    Oplogo Changer
    Restart and Shutdown
    WinRAR
    Giftylor
    MemCheck
    Phone Torch
    Nokia FileBrowser
Please, dont forget this step while flashing.
Here, before you press ' Refurbish button ', click on Option below and delete files like Rofs2,Rofs3,mmc content and other fpsx file.
There should be only two files, Core and UDA.
See the screenshot below:
Ok guys, Don't forget to leave your results,suggestions,complaints,etc here or via PM.
Thanks everyone.
pas : sameer
ENGLISH only
see the Screenshots here.
hic, bản này k có tiếng việt hả mọi ng ?
uk.chỉ có tiếng Anh thôi hay sao ý.Mấy pro trong diễn đàn mình đâu hết rồi,không ai add tiếng Việt vào cho ngon lành nhỉ...haiz....chờ dài cổ rồi
cho minhf link medifire vowis
ko ai đả đọng đến cfw này nữa à.t vừa mới mua con c5 mà ko biết hack kiểu nào.xin pro chỉ với
Ủa. Cái này có cấn phải thêm 1 file hach k vậy hay là cứ như thế chạy thẳng lun hả mấy bạn 8-|
Bây giờ còn rất ít người dùg v3 nên thay vì hỏi các bạn nên tự test sẻ có câu trả lời nhanh hơn,còn vấn đề hack phone các bạn sang đây để xem hd nhé
http://www.pdaviet.net/showthread.php?155553-hck-phone-symbian-s60v3-don-gian-voi-norton-symbian-hck
