TP.HCM Docomo Sony SO-02C (Acro) unlock ok !
Taki7610
Unlock_GSM
Mã:
7/5/2013 5:50:33 PM DETACH USB CABLE FROM PHONE
7/5/2013 5:50:33 PM REMOVE BATTERY FROM PHONE
7/5/2013 5:50:33 PM ATTACH TESTPOINT
7/5/2013 5:50:33 PM PRESS "READY", THEN ATTACH USB CABLE TO PHONE
7/5/2013 5:50:33 PM
7/5/2013 5:50:45 PM PROCESSING ...
7/5/2013 5:50:46 PM REMOVE TESTPOINT NOW, THEN PRESS "READY"
7/5/2013 5:50:46 PM
7/5/2013 5:50:51 PM PLEASE ATTACH TURNED OFF PHONE NOW
7/5/2013 5:50:51 PM PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
7/5/2013 5:50:53 PM
7/5/2013 5:50:53 PM RUNNING S1_EROM VER "R9A022"
7/5/2013 5:50:53 PM
7/5/2013 5:50:53 PM EROM_AID : 0001
7/5/2013 5:50:53 PM LOADER_AID : 0001
7/5/2013 5:50:53 PM SW_AID : 0001
7/5/2013 5:50:53 PM CUST_AID : 0001
7/5/2013 5:50:53 PM SIM_LOCK_AID : 0001
7/5/2013 5:50:53 PM
7/5/2013 5:50:54 PM FATAL ERROR [ SECURITY_CLASS, SIN_header_verification_failed ]
7/5/2013 5:50:54 PM error while uploading HDR block
7/5/2013 5:50:54 PM LOADER NOT STARTED
7/5/2013 5:50:54 PM FAILED TO SETUP PHONE
7/5/2013 5:50:54 PM Unlock FAILED
7/5/2013 5:50:54 PM Elapsed: 21 secs.
7/5/2013 5:51:25 PM SIGNED MODE (USING SERVER)
7/5/2013 5:51:25 PM ALTERNATIVE SECURITY BYPASS ENABLED
7/5/2013 5:51:25 PM CFG:110010000000
7/5/2013 5:51:27 PM
7/5/2013 5:51:27 PM DETACH USB CABLE FROM PHONE
7/5/2013 5:51:27 PM REMOVE BATTERY FROM PHONE
7/5/2013 5:51:27 PM ATTACH TESTPOINT
7/5/2013 5:51:27 PM PRESS "READY", THEN ATTACH USB CABLE TO PHONE
7/5/2013 5:51:27 PM
7/5/2013 5:51:38 PM PROCESSING ...
7/5/2013 5:51:39 PM REMOVE TESTPOINT NOW, THEN PRESS "READY"
7/5/2013 5:51:39 PM
7/5/2013 5:51:49 PM PLEASE ATTACH TURNED OFF PHONE NOW
7/5/2013 5:51:49 PM PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
7/5/2013 5:51:49 PM
7/5/2013 5:51:50 PM RUNNING S1_LOADER VER "R4A069"
7/5/2013 5:51:50 PM
7/5/2013 5:51:50 PM EROM_AID : 0001
7/5/2013 5:51:50 PM LOADER_AID : 0001
7/5/2013 5:51:50 PM HWCONF_AID : 0001
7/5/2013 5:51:50 PM ACTIVE_LOADER_AID : 0001
7/5/2013 5:51:50 PM
7/5/2013 5:51:51 PM DEVICE ID: 34DFCDA43BD64368EC3E1C0A7C21203673F472DA
7/5/2013 5:51:51 PM FLASH ID: "0098/00B3"
7/5/2013 5:51:51 PM LOADER VERSION: "r4A069"
7/5/2013 5:51:51 PM
7/5/2013 5:51:51 PM PHONE IMEI : 35798504543913
7/5/2013 5:51:51 PM Checking for signature ...
7/5/2013 5:51:55 PM WRITING SEMCBOOT ...
7/5/2013 5:51:58 PM Unlock DONE
7/5/2013 5:51:58 PM Elapsed: 32 secs.
Mã:
7/5/2013 5:50:33 PM DETACH USB CABLE FROM PHONE 7/5/2013 5:50:33 PM REMOVE BATTERY FROM PHONE 7/5/2013 5:50:33 PM ATTACH TESTPOINT 7/5/2013 5:50:33 PM PRESS "READY", THEN ATTACH USB CABLE TO PHONE 7/5/2013 5:50:33 PM 7/5/2013 5:50:45 PM PROCESSING ... 7/5/2013 5:50:46 PM REMOVE TESTPOINT NOW, THEN PRESS "READY" 7/5/2013 5:50:46 PM 7/5/2013 5:50:51 PM PLEASE ATTACH TURNED OFF PHONE NOW 7/5/2013 5:50:51 PM PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 7/5/2013 5:50:53 PM 7/5/2013 5:50:53 PM RUNNING S1_EROM VER "R9A022" 7/5/2013 5:50:53 PM 7/5/2013 5:50:53 PM EROM_AID : 0001 7/5/2013 5:50:53 PM LOADER_AID : 0001 7/5/2013 5:50:53 PM SW_AID : 0001 7/5/2013 5:50:53 PM CUST_AID : 0001 7/5/2013 5:50:53 PM SIM_LOCK_AID : 0001 7/5/2013 5:50:53 PM 7/5/2013 5:50:54 PM FATAL ERROR [ SECURITY_CLASS, SIN_header_verification_failed ] 7/5/2013 5:50:54 PM error while uploading HDR block 7/5/2013 5:50:54 PM LOADER NOT STARTED 7/5/2013 5:50:54 PM FAILED TO SETUP PHONE 7/5/2013 5:50:54 PM Unlock FAILED 7/5/2013 5:50:54 PM Elapsed: 21 secs. 7/5/2013 5:51:25 PM SIGNED MODE (USING SERVER) 7/5/2013 5:51:25 PM ALTERNATIVE SECURITY BYPASS ENABLED 7/5/2013 5:51:25 PM CFG:110010000000 7/5/2013 5:51:27 PM 7/5/2013 5:51:27 PM DETACH USB CABLE FROM PHONE 7/5/2013 5:51:27 PM REMOVE BATTERY FROM PHONE 7/5/2013 5:51:27 PM ATTACH TESTPOINT 7/5/2013 5:51:27 PM PRESS "READY", THEN ATTACH USB CABLE TO PHONE 7/5/2013 5:51:27 PM 7/5/2013 5:51:38 PM PROCESSING ... 7/5/2013 5:51:39 PM REMOVE TESTPOINT NOW, THEN PRESS "READY" 7/5/2013 5:51:39 PM 7/5/2013 5:51:49 PM PLEASE ATTACH TURNED OFF PHONE NOW 7/5/2013 5:51:49 PM PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... 7/5/2013 5:51:49 PM 7/5/2013 5:51:50 PM RUNNING S1_LOADER VER "R4A069" 7/5/2013 5:51:50 PM 7/5/2013 5:51:50 PM EROM_AID : 0001 7/5/2013 5:51:50 PM LOADER_AID : 0001 7/5/2013 5:51:50 PM HWCONF_AID : 0001 7/5/2013 5:51:50 PM ACTIVE_LOADER_AID : 0001 7/5/2013 5:51:50 PM 7/5/2013 5:51:51 PM DEVICE ID: 34DFCDA43BD64368EC3E1C0A7C21203673F472DA 7/5/2013 5:51:51 PM FLASH ID: "0098/00B3" 7/5/2013 5:51:51 PM LOADER VERSION: "r4A069" 7/5/2013 5:51:51 PM 7/5/2013 5:51:51 PM PHONE IMEI : 35798504543913 7/5/2013 5:51:51 PM Checking for signature ... 7/5/2013 5:51:55 PM WRITING SEMCBOOT ... 7/5/2013 5:51:58 PM Unlock DONE 7/5/2013 5:51:58 PM Elapsed: 32 secs.
Oánh dấu về nghiên cứu sau.
