NguyenTu
Super V.I.P
Documents To Go® Premium - Office Suite
![](http://ni1.upanh.com/b6.s15.d1/6bb7706914c9d889b2d1052abc146676_40831071.8.jpg)
Version: 4.0.7
This app is designed for both iPhone and iPad
$16.99
Category: Business
Updated: Jan 05, 2012
Version: 4.0.7
Languages: English, French, German, Italian, Portuguese, Spanish
Seller: DataViz, Inc
© 2010 DataViz, Inc.
Requirements: Compatible with iPhone, iPod touch, and iPad.Requires iOS 3.2 or later
Version: 4.0.7
$16.99
Category: Business
Version: 4.0.7
![mzl.iapxrkvz.320x480-75.jpg](http://a3.mzstatic.com/us/r1000/096/Purple/2f/21/c1/mzl.iapxrkvz.320x480-75.jpg)
![mzl.igskxcqp.320x480-75.jpg](http://a3.mzstatic.com/us/r1000/083/Purple/18/8f/e6/mzl.igskxcqp.320x480-75.jpg)
![mzl.fxxuasgv.320x480-75.jpg](http://a1.mzstatic.com/us/r1000/102/Purple/60/c7/16/mzl.fxxuasgv.320x480-75.jpg)
![mzl.kfeqzemf.320x480-75.jpg](http://a5.mzstatic.com/us/r1000/089/Purple/a2/53/2e/mzl.kfeqzemf.320x480-75.jpg)
THÔNG TIN
Description
Looking to access your Microsoft Office ® files at any time? All you need is your favorite iOS device and Documents To Go in order to be constantly connected!
The latest update to Documents To Go Premium includes an improved SlideShow To Go full screen mode & better slide navigation alongside numerous bug fixes!
What can I do with "DocsToGo Premium"?:
• EDIT, CREATE & VIEW Word, Excel & PowerPoint files (Office 2007/2008/2010)
• VIEW/EDIT/SYNC your cloud files! Support includes Google Docs, Dropbox, Box.net, iDisk & SugarSync
• VIEW PDF, iWork, Text, .RTF files, and more!
• iPad/iPhone 4/iOS 4: Send & receive attached supported documents using the built-in Mail app
• FREE desktop application with your purchase! Compatible on Win & Mac, this app allows you to access desktop files and sync with a WIFI connection.
• Open & Edit files within DocsToGo from any 3rd party app that supports the iOS 4 "Open In" feature*
• Supports iTunes File Sharing via USB cable for manually moving files*
*iOS 4 or 5 only
THE DATAVIZ® ADVANTAGE
Documents To Go, now in its 13th year, is developed by DataViz, Inc., a producer of quality software for Macs & PCs for over 26 years. DocsToGo is currently preloaded on millions of devices around the world.
Word To Go Features:
• Various bullet styles
• View/Edit/Create Word (.doc, .docx) files
• Various bullet styles/formatting
• InTact Technology retains original document formatting of edited files
• High fidelity VIEWING: embedded graphics, tables, comments, footnotes/endnotes, text boxes, table of contents & hyperlink
• Now opens password protected Word 97-2008 files
• Extensive character formatting & paragraph alignment
• Auto bullets/numbers
• Multiple Undo/Redo
• Find & Replace
• Word Count
Sheet To Go Features:
• NEW! Freeze Panes and Sort
• View/Edit /Create Excel (.xls, .xlsx) spreadsheets
• Includes support for Freeze Panes and Sort
• Freeze rows/columns
• 111 functions
• Open password protected Excel 97-2008 files
• Extensive cell & number formatting
• Insert/delete/resize/hide/unhide rows & columns
• Rename/insert/delete sheets
• Multiple worksheets
• Find/Find Next
SlideShow To Go Features:
• Improved Full Screen Slide Navigation and Edit Mode!
• View, edit & create PowerPoint (.ppt, .pptx) files
• Editing features available in Improved Edit mode & speaker notes
• Editing includes: Multiple Undo/Redo, Insert/delete/duplicate/sort slides, Go to slide, Promote/demote bullets, Find & Replace
PDF To Go VIEWING Features:
• Thumbnail, Fit to Screen, Fit to Width, Actual Size & full screen views
• Go to/rotate page
• Open password-protected PDFs
Cloud Synchronization:
*Supports GOOGLE DOCS, DROPBOX, BOX.NET, IDISK & SUGARSYNC *
• Download, view, edit & sync files from Google Docs, Dropbox, Box.net, iDisk & SugarSync directly in DocsToGo
• Upload files from iPad/iPhone/iPod to your cloud or online storage account seamlessly
FREE Desktop Application:
*Free desktop app for 2-way file sync using WIFI*
• Sync & transfer files/folders in one easy-to-use desktop app
• Downloadable on a Windows or Mac computer
System Requirements:
• iOS device running iOS 3.2 +
• WIFI router with multicasting capabilities
• Win XP, Vista, 7 & Bonjour
• Mac OS X 10.4.10 or above (G3 Macs not supported)
• Desktop sync requires device to be connected via WIFI to same network/IP address as computer
Description
*iOS 4 or 5 only
• Find & Replace
• Word Count
• 111 functions
• Find/Find Next
• Go to/rotate page
