NguyenTu
Super V.I.P
EZMP3 Player
![](http://nj4.upanh.com/b5.s24.d2/303147f3d72ffecb3d7209b2796e1b0b_41888904.3.jpg)
Version: 1.4.0
Free
Category: Utilities
Updated: Mar 10, 2012
Version: 1.3.0
Languages: English, Italian, Japanese, Korean
Seller: YOO JIN NO
© Copyright 2012 yTechMobile. All rights reserved.
![mzl.igitkclf.320x480-75.jpg](http://a3.mzstatic.com/us/r1000/083/Purple/bb/e5/fd/mzl.igitkclf.320x480-75.jpg)
![mzl.iwxzasmf.320x480-75.jpg](http://a4.mzstatic.com/us/r1000/067/Purple/12/62/f9/mzl.iwxzasmf.320x480-75.jpg)
![mzl.wxweqdcy.320x480-75.jpg](http://a2.mzstatic.com/us/r1000/073/Purple/48/8e/5f/mzl.wxweqdcy.320x480-75.jpg)
![mzl.ipzipmps.320x480-75.jpg](http://a1.mzstatic.com/us/r1000/093/Purple/b9/7c/55/mzl.ipzipmps.320x480-75.jpg)
THÔNG TIN THÊM
Description
EZMP3 Player is a music player which can play MP3 and M4A (Apple's Lossless Music
File Format) files.
You can directly input your music files and there is no need of iTunes sync.
When operating using remote control, you can use beep sound effect and special features like
deleting files.
◼Features
-Unlock Screen Display
- Supports Lyrics Display
- Copy Function of Music Files for iPod library (Only available for PRO ver.)
- Bitrate Display of MP3/M4A file info
- Supports all language encodings of id3 tags
- No need of iTunes sync
- File transter via WiFi. Simultaneous transfer of multiple files
- File transfer via USB
- "Delete Files" function supported in remote control (special features are executed by pressing the button three times in a row)
- Beep sound effect in remote control mode
- Direct (manual) management of folders & files
- Create playlists
- Supports id3 tags
- Implementation of visual effect for sound pressure while playing music
- Supports Multitasking
- Album/Artist Gallery
File Format) files.
deleting files.
◼Features
- Create playlists
- Supports id3 tags
