Flash Stock Rom MOTO DROID 2 A956 !
Taki7610
Unlock_GSM
Máy bị treo flash lại ok
***Wipe full :
  1. Slide the keyboard open.
  2. Press and hold the Power button+X key simultaneously until the Recovery screen (exclamation point with an android figure) appears.
  3. From the Recovery screen, press the Search key.
  4. Select wipe data/factory reset.
    Utilize the Volume keys (up / down) to highlight and the Camera key to select (keys located on the right-side of the device).
    If necessary, slide the keyboard to the closed position.
  5. Select Yes -- delete all user data.
    Allow the factory reset process to complete (approximately 1 minute).
  6. Select reboot system now.
    Allow several minutes for the reboot process to complete.
  7. Consulta Activación y configuración inicial.
thanks
***File Flash Stock :
- Vào Boot Mode : volume + - power
- Active phone chạm 4 góc màn hình là ok .
