congtukiem
![FormatFactory.jpg](http://www.formatoz.com/images/FormatFactory.jpg)
Convert music CD to MP3,WMA,OGG,AAC....
![FFCDRip.jpg](http://www.formatoz.com/images/FFCDRip.jpg)
Convert video DVD to MP4,3GP,AVI,WMV....
![FFDVDRip.jpg](http://www.formatoz.com/images/FFDVDRip.jpg)
Description:
Format Factory is a multifunctional media converter.
Provides functions below:
All to MP4/3GP/MPG/AVI/WMV/FLV/SWF.
All to MP3/WMA/AMR/OGG/AAC/WAV.
All to JPG/BMP/PNG/TIF/ICO/GIF/TGA.
Rip DVD to video file , Rip Music CD to audio file.
MP4 files support iPod/iPhone/PSP/BlackBerry format.
Supports RMVB,Watermark, AV Mux.
Format Factory's Feature:
1 support converting all popular video,audio,picture formats to others.
2 Repair damaged video and audio file.
3 Reducing Multimedia file size.
4 Support iphone,ipod multimedia file formats.
5 Picture converting supports Zoom,Rotate/Flip,tags.
6 DVD Ripper.
7 Supports 56 languages
OS requirements: All 32 windows OS
Change Logs:
List of Version 2.45 changes
1 Fix a problem that AVC MP4 can't be played correctly in version 2.40
2 Added the option whether install FormatFactory inside codecs to system.
List of Version 2.40 changes
1 Fix the problem of Apple's MP4 time is twice as long as the original.
2 Improve the configuration of "All to Picture",now it can be saved as "All to Custom".
3 Added several profiles of some latest devices.
4 Fix a bug that fail to clip video when adding watermark.
Frequently Asked Questions:
Question : Appear error message "Missing FFMpeg.dll".
Answer:Please uninstall older version or empty the FormatFactory folder first , then install new version again.
Question : when I use "All to RMVB",appear error message "Fail to decode".
Answer:FormatFactory use system installed codec to decode sourec files. you must install some codec that your files needed. You can install "K-Lite" or other codec pack to solve this problem.
Question : How to make VCD/DVD.
Answer:FormatFactory only support file to file conversion. You can convert to MPG ,then use "Nero" to burn VCD/DVD.
Question : When I try to rip DVD , several of my dvds get errors.
Answer:Please click mencoder.rar download and unrar it , then replace "FormatFactory\FFModules\mencoder.exe" in FormatFactory installation folder.
Question : After I convert a movie with subtitle, the result come out without character ç, ã, é and Á.
Answer:Because the defaut font doesn't support these character , Please change subtitle font to "Tahoma (Tahomabd.ttf)"
Link download : http://www.4shared.com/file/XYPIUvrw/FormatFactorySetup245_symbianz.html
