Hard-SPL V9!
Taki7610
Unlock_GSM
Thêm một TOOL dành Hard-SPL cho dòng HERMES của Olipro's
Khi các bạn chạy thành công thì SPL sẽ là 2.60.Như vậy là máy bạn đã UnlockCid thành công,có thể Up các bản ROM khác .
Tham khảo thêm : LINK
Mã:
CURRENT FEATURES
-SuperCID
-no file signing required
-no password required to authenticate with bootloader
-bad NAND can be recovered with "task 2a"
-bad NAND can be recovered by flashing an OS
-SPL protected from all HTC retail SPLs being flashed by accident (to bypass, use SSPL)
-IPL protected from all flashes; protection against bogus NBH's
-bad NAND can again be checked for with "info 8"
-version displays 2.60.Olipro
-no longer tries to read bad NAND - should fix whitescreen issue
-lnbs command converted to lnb
-rtask command ported back; "rtask 7" replaces "rtask b"
-can be overwritten with a special NBH
ChangeLog
Hard-SPL-2.60
-ported rtask back into the bootloader
-special NBH can be made to overwrite SPL
-lnbs now converted to lnb
-special credits in info 7 command :)
Hard-SPL-2.30
-Unlocked RBMC command; internal release only
Hard-SPL-2.10
-based on a newer SPL base; bugfixes.
-IPL flashing disabled to prevent bogus NBHs bricking your device.
Hard-SPL-1.40
-repairs a bug that affected SPL being replaced by retail ones.
Hard-SPL-1.35
-addresses an issue for those with Real Bad Blocks to prevent whitescreens.
Hard-SPL-1.30
- removed password for wdata commands and rbmc etc.
- activated "task 2a" to allow recovering bad blocks as well as flashing valid OS.
- Disabled SPL flashing; this SPL protects you from writing over it by accident.
- Bad Blocks "info 8" command works now allowing you to check for bad blocks.
Hard-SPL-1.13
- Patched NAND check; bad NAND ignored, valid OS can be flashed to recover bad blocks.
Hard-SPL-1.11
- Flashing Radio BL 0108 now supported
- Downgrading SPL no longer allowed.
- rtask command removed.
- new RUU interface required to flash ROM files.
Hard-SPL-1.10
-Initial release; SuperCID and no signing required
-Compatible only with Radio BL 0107
-has rtask commands for accessing radio facilities.
Hard-SPL-v9.zip
Cái này không đơn giản là up một cái là vào ngay đâu bác, phải hạ xuống H-SPL 1.11 thì mới có thể up được. Bác đã up thành công rồi phải không? Cho em xin cái H-SPL 1.11 với nghe. Thanks bác trước hen.
cứu mình với...ko để ý phải downgrade xuống SPL 1.11 ,mình để nguyên SPL 2.10 mà up lên thì nó báo lổi ko up dc bây giờ nó treo máy tại bootloader rồi cứ reset thì nó hiện lên màn hình bootloader
Bạn tìm lại rom gốc up vào rồi downgrade xuống SPL 1.11
SPL 2.10 up rom kho chui lắm
Cắm cáp nối với PC, lấy file ROM sửa tên lại thành HERMIMG.nbh rồi copy vào thẻ nhớ (đã format bằng định dạng FAT32), đưa về bootloader rồi up lại từ thẻ nhớ là OK thôi bạn.
Mấy vụ H-SPL này không phải đơn giản nên mấy bác mod có giới thiệu thì nhớ test trước nha mấy bác.
Bác cho em cái link down bản SPL 1.11 với nhé.
H-SPL 2.10 là up ROM ổn định nhất ấy chứ. Mình up cả trăm lần thấy có bị gì đâu bác nói khó chịu ta? Cụ thể là nó khó chịu thế nào vậy bác.
- Nếu máy đã có HardSPL rồi, kể cả 1.30 hay 1.40, 2.10, thì cứ để đó mà dùng, version mới thì có ảnh hưởng nhiều lắm đâu.
Nếu muốn thay đổi lên số cao, ví dụ 2.60, thì đòi hỏi phải hạ xuống SPL-1.11 trước.
- Còn máy mới chưa chạy lần nào, cứ dùng SSPL-herm chạy trên PPC để đưa máy vào Bootloader và Up V7 hay V9 nào cũng được hết.
Dùng cách Up từ thẻ như bạn GauEm nói trên cũng tốt, khá an toàn.
Những gì mình gởi lên đây đa số mình đều đã test rồi mới đưa lên - Mình đã chạy HardSPL-V9 và Up ROM ok của Trial mod PhamNhatThanh - Con SoftBank-HERMS 200!
downgrade xuống SPL 1.11 bằng cách nào vậy bro.Bro có thể cho mình nic YM dc ko.Mình đã up rom gốc của con Dopod 838pro dc rồi.Bây giờ nó đã hết treo ở bootloader vào Win bình thường.Nhưng Bootloader của nó vẫn là SPL 2.10oliver
Vậy bác cho em cái link down bản H-SPL 1.11 mà bác đã hạ xuống trước khi up V9 nhé. Hoặc là bác đính kèm theo cho em nhé. Thanks bác trước hen.
Mình nói bác rồi, cứ để H-SPL 2.10 mà dùng, đừng có up lên V9 làm gì.
Của bạn đây-Hard-SPL-V6.zip - fixed RUU bug for those using 1.11/1.13/1.30
Tham khảo thêm tại đây : LINK
Mã:
http://www.mediafire.com/?ym1laxji2gd
Máy Softbank mình làm mặc định là W2K5-SPL 2.10 Oliver
Như Chú Quang đã nói ỡ trên-tất cả các đều chung là UnlockCid cho máy mà thôi
Mã:
Bác ơi bác, chắc bác chưa up H-SPL lần nào phải không? Bản V6 mà bác đưa là H-SPL 1.40Oli đó bác, ghi fixed RUU bug for those using 1.11/1.13/1.30 nghĩa tiếng Việt đâu phải nó là H-SPL 1.11 đâu bác.
Up tấm hình bản V6 mà bác đưa cho em lên cho bác tham khảo cái hen.
Bác hạ xuống H-SPL1.40Oli mà bác cũng up lên được V9 àh. Hay vậy ta. :O:-?
Mình chỉ nói theo "kinh nghiệm' của mình mà thôi bạn à-Vì "xương máu" rồi-Thú thật thì chưa bao giờ mìh chạy HSPL V6 cả-mìh chỉ chạy Hard-SPL-V7 mà thôi-Khi mìh chạy con Softbank bằng Hard-SPL-V7 xong,mìh mới bắt đầu "thử 'Hard-SPL-v9-ban đầu màn hình trắng xóa nhưng sau đó ko có chữ Configution mà lại báo lỗi "kết nối"-Mìh chuyễn qua BL thì SPL như cũ-Phỉa chạy 2 lần thì có SPL 2.60.
P/s : Mìh không bàn ở đây ta nên dùng cái này hay cái kia,cái nào tốt hay ko tốt,tùy từng người mà sử dụng thik hợp mà thôi.Mìh đưa lên đây ko có nghĩa là "đưa đại-ai test chết ráng chịu" Mà mìh đã "đi trước và ok" nên đưa lên cho ah em tham khảo mà thôi.
Bác ơi bác, em xin cái H-SPL 1.11 để up cái V9 ( vì bác nói là bác đã up và đã test trước khi giới thiệu rồi, mà để up được V9 thì tất nhiên là bác đã phải down xuống H-SPL 1.11 rồi ), mà bác lại đưa cái H-SPL V6 cho em rồi vòng vo qua lại.
Một bài Post lên là sự tìm tòi cực nhọc
các Bạn nên góp ý chứ dừng tranh luận
Nếu GauEm có kinh nghiệm về vấn đề này, mời bạn nêu kinh nghiệm để chia sẽ với mọi người, sao lại phải đi tranh luận thế này. Mình để ý nhiều bài của bạn, chẳng có tinh thần xây dựng chút nào! Xin mời bạn chia sẽ kinh nghiệm!
Ẹc ẹc, bác Taki nói bác ấy up được, trong khi bộ tool thì nói là phải trả về H-SPL 1.11 thì mới up được, em thấy bác ấy up được nên em xin cái H-SPL 1.11, trong khi bác ấy lại cho em cái H-SPL V6 1.40. :-??
Có vậy thôi mà bác, sao bác lại nói em không có tinh thần xây dựng? :-??
Bạn nêu cách bạn làm để mọi người cùng test! Mình chỉ muốn vậy thôi!
Bác đi hỏi bác Taki ấy, bác ấy up được rồi kìa, em có tìm được bản H-SPL 1.11 đâu.
Bác này sao ấy nhỉ? Người làm được thì không hỏi, đi hỏi người không làm được. :-/
Bro Gauem làm theo cách này nè...mình đã up dc lên 2.6
đầu tiên tải bản SPL 1.10 tại http://forum.xda-developers.com/attachment.php?attachmentid=76004&d=1205633147
sau đó chạy file ROMUpgradeUt.exe nhớ là vẫn để sync nha.. Sau khi Up xong, bạn đưa máy về bootloader kiểm tra lại, nếu thấy dòng SPL là SPL-1.10.Oli là được.
Rồi tiếp tục chạy cái V9,nhưng nhớ là vẫn để sync để PPC với PC trước,khi chạy file ROMUpgradeUt.exe sẽ tự động đưa máy về Bootloader
