Cho mình hỏi có pm nào cho phép cấu hình vị trí save mặc định của tất cả các soft trong ppc (note, word, ...) là SD card ko?
Thanks,
Tham khảo nhé
Change the location of My Documents
Documents are opened in and saved to the device's internal storage by default. You can change this location to, for example, your Storage Card:
HKLM\Software\Microsoft\Windows CE Services\FileSyncPath = "\Storage Card\My Documents" (REG_SZ string, no quotes)
To return to the original location:
HKLM\Software\Microsoft\Windows CE Services\FileSyncPath = "\My Documents" (REG_SZ string, no quotes)
Change the location of email and attachments
When reading and sending email in Pocket Outlook, emails and their attachments are saved in the device's internal storage by default. You can change this location to, for example, your Storage Card:
HKCU\Software\Microsoft\MAPI\PropertyPath = "\Storage Card\Mail" (REG_SZ string, no quotes) HKCU\Software\Microsoft\MAPI\AttachPath = "\Storage Card\Mail\Attachments" (REG_SZ string, no quotes)
Just simply delete these Registry settings (since neither is included by default).
Change the location of Temporary Internet Files
When browsing the web, pages and images are saved in the 'Temporary Internet Files' location. You can change this location to, for example, your Storage Card:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Cache = "\Storage Card\cacheie" (REG_SZ string, no quotes)
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Cache = "\Windows\Profiles\guest\Temporary Internet Files" (REG_SZ string, no quotes)
Change the location of Ringtone file storage
WM5 will look for Ringtones in \Windows\ or \Windows\Rings by default. You can change this location to, for example, your Storage Card (example given is for ringtones placed on the Storage Card root folder)
HKCU\ControlPanel\?SoundCategories\Ring\Directory = "\Storage Card\" (REG_SZ string, no quotes)
HKCU\ControlPanel\?SoundCategories\Ring\Directory = "\Windows\Rings\" (REG_SZ string, no quotes)
Note the default location may be "\Windows\" or "\Windows\Rings\" depending on your Device provider.
