Show or hide the Recycle Bin
The Recycle Bin usually appears on the desktop. If you prefer, you can hide it.
To show or hide the Recycle Bin on the desktop
Click to open Personalization.
In the left pane, click Change desktop icons, and then do one of the following:
To remove the Recycle Bin from the desktop, clear the Recycle Bin check box.
To display the Recycle Bin on the desktop, select the Recycle Bin check box.
Click OK.
Bác có thể nhấn F1 có Help đủ hết
