Thangnd31082
TTPod v3.7.0 Final
Phần mềm nghe nhạc cực đỉnh đã xuất hiện bản Final
Sau bao ngày chờ đợi thì bản Final của TTPod 3.7 [CN] đã xuất hiện trên giang hồ , anh em chờ CaoMinh Việt hóa nó nhé !
Nguyên văn phần giới thiệu :
Every day is a pleasant to the ears are not required to register, completely free cell phone music player software, set playback, equalizer, lyrics, sleep mode, alarm clock and many other functions, operation simple and powerful. Every day, appealing to the user's need for the development direction and strive to become the user in mind the best player, becoming the most popular cell phone music player software.
Change Log:
New and Improved:
1. Decoded based on a new system architecture to improve performance and results, reduce the CPU occupancy and power consumption;
2. Increase environmental sound adjustment function;
3. Increase the left and right channel balance adjustment function;
4. Optimizing the majority of pop-up box interface display;
5. The new image processing engine, better display;
6. Increase the image rotation display;
7. To increase picture lantern display;
8. Increase the image rotating display;
9. Add "1" key shortcut menu;
10. Optimal adjustment of left menu layout;
11. Increase the power-saving mode;
12. Increase in night mode;
13. Increase by album name, by adding time to sort random ranking;
14. Increase the tag and mobile functionality;
15. Increase the smooth fast forward / rewind mode;
16. Increase the font Stroke effect;
17. Increase the font shadow effects;
18. Increase the font size and color of the lyrics interface regulatory function;
19. Increase the image storage directory customization;
20. To increase the transparency of regulatory function mini player;
21. Support "start play" and "Memory out of position" set separately;
22. Support the left-menu press the left arrow keys to turn off;
23. Optimizing the speed list, scroll and flip;
24. Custom list add "Favorites" list by default;
25. Bluetooth to send support for sending multiple files at the same time;
26. ID3 editor cache optimization methods to improve save rates;
27. Increase the power, the progress bar handle and follow the syntax of animation, and more skin.
Fixes:
1. FP2 models to solve the problem sleep shutdown mode is invalid;
2. Repair some models use JbakTaskMan forcibly closed by the procedure leading to the problem restart the phone;
3. Repair 3250/5500 and other models for music when the phone reboot problems;
4. Fix built-in picture screen in the switch anyway, or skin problems do not appear;
5. Repair part of the model image display area width ranging from pictures shown due to gaps;
6. Fix MPEG-4 AAC Audio Coding format, the problem can not play audio;
Notes:
* N82, N95, N73 sound problems due to environmental hazards, have been shielded environment sound;
* Samsung models sound API call is invalid, has been shielded sound and equalizer options;
* N82, N95 backlight control to open the screen flashes when the cause has been screened the night mode.
Thanks GENERY and his screenshots..
Download:
1. Tải trực tiếp từ trang chủ : http://www.ttpod.com/index.php#down_show
2. Tải về từ mediafire.com
Không muốn dùng Google dịch bừa nên tạm thời để nguyên bản giới thiệu bằng tiếng Anh , sẽ cập nhật trong thời gian sớm nhất !
