How to enable FP2 style transitions in FP1 devices (For Nokia n82)
tuancoild
mình vừa tìm được phần hiệu ứng cho menu fp1-fp2, mấy bác " pro" nghiên cứu dùm mình nha, giờ bận quá phải đi công chuyện tý lát về nghiên cứu tiếp, mấy bác coi thử khác bài của dung1291985 không nha, hình như hiệu ứng này dành cho các loại FW mới , đoạn phim hướng dẫn ở đây http://redpepper007.ucoz.com/news/2009-01-09-52
***READ THIS BEFORE STARTING***
You'll need:
-A hacked phone with ROMPatcher and a file browser(like Y-Browser or x plore) installed. [Download rompatcher, Download x plore, Download y browser]
-To make sure that all of your themes are installed on the C drive(internal memory).
1)Download the KastorUI zip file from here: extract it and then copy the Kastor UI folder to your phone's memory card.
2)Disable platform security either by using CapsOff or ROMpatcher and then use a file browser navigate to the KastorUI folder and copy the KastorUI.rmp file to the patches folder on your memory card.
3)Copy the entire effects folder(from the KastorUI folder) into C:\Resource.
4)Copy the effects.sel file(from the KastorUI folder) and then navigate to C:\Resource\skins. In here, paste the effects.sel file into each of the folders and then rename it to the name of the folder. For example, if the name of a folder was 2000d1c3, you would rename effects.sel to 2000d1c3.sel.
5)Exit your file browser and then open ROMPatcher. Enable the KastorUI patch and set it to start automatically.
6)Navigate to the themes application, highlight your current theme and press options, select theme effects and then turn them off and back on again. *DO NOT EXIT THEMES* Instead, press the Symbian Menu button to open the menu and voila, your theme effects are working!
Every time you turn off your phone, simply repeat step 6 to get your theme effects back.
chả có gì khác đâu bạn, vẫn là Theme effect mà chỉ có các máy firmware cũ v15 mới có thui .... close topic :(
sao mình thấy nó bảo dành cho N82 vậy Dung, bạn xem lại dùm mình xem sao, chưa có thời gian test nữa
hix đang mừng hụt nè, cứ tưởng N82 v31 được rùi chứ, thôi lát về nghiên cứu tiếp, có rãnh thử lại xem sao đã :-?
