HTC Polaris tweaks and tricks
BraDo
Lang thang sưu tầm đc 1 số tinh chỉnh Registry Polaris để vọc, nếu có thể các bạn bổ sung thêm nhé
1. Use 6 Tabs with htc home: (Thay đổi tab trên HTC Home)
HKLM\Software\HTC\HTCHome
Add new string,
Tabsetting = 1,2,3,4,5,6
You can change the order of the numbers to sort the tabs how you like
1 = Clock tab
2 = Favorite People tab
3 = Weather tab
4 = Launcher tab
5 = Music tab
6 = Profiles tab
refresh the htc home to get the tabs u can do it by unchecking the today contects and then checking it and it will refresh and
people who missed the favorites home tab delete this registry key :
HKLM\Software\OEM\MASD\Quickdial
delete it an drefresh thats alll and u will get all the 6 tabs !!
2- To activate the GPS photo (thay đổi GPS photo)
HKLM\SOFTWARE\HTC\Camera
In the directory P9 pass value "enable" 1
3. To SpeedUp Touch Flo: (làm xuất hiện nhanh Touch Flo)
HKLM\Software\HTC\Biotouch\Biotouch\ change and change "DownFPS", "LightFPS" and "UpFPS" from 15 to 50
4. Touchflo sensitivity: (tăng độ nhạy Touch Flo)
HKLM\Drivers\Touchpanel\Pressure Threshold
change from default 18866 to 19866 or 20866 or more 40866 makes the scroll better
5. Change image pad when taking picture with camea from DCIM to storage card\my documents: (thay đổi folder khi chụp hình)
HKLM \Software\HTC\Camera\General
change EnableDCIM from 1 to 0
this will change the default path to save image from
Storage card\DCIM\100MEDIA to storage card\my documents
6. Change directory of "Photo gallery" in Touch Cube (thay đổi folder lưu hình ảnh khi chọn "Photo gallery" trên thẻ nhớ)
"HKLM\Software\HTC\Camera\Image" there is a "SaveFolder_0409", change the last number from 0409 na 0405. Then softreset and you will be able to browse (in the touch cube) pictures you made and are stored on storage card
7. Increase the sensitivity for all screen presses: (tăng độ nhạy cảm ứnh)
HKLM\software\OEM\TFLOSettings\FingerPressure
Change from default 2908 to 10892
8. Speedup Touch Flo by increasing Frames Per Second (tăng nhanh chuyển trang Touch Flo)
- HKLM\Software\HTC\Biotouch\Biotouch\
- Change "DownFPS", "LightFPS" and "UpFPS" from default 15 to 60
- Change "LeftRightFPS" in 60
9. How to change the date format on the Today screen: (thay đổi định dạng ngày trên HTC Home)
HKLM\nls\overrides\
Edit or create new string:
Value: ddd, dd MMM yy --> Sat, 02 Feb 08 (what I have now)
or for example
dddd-dd MMMM-YYYY --> Saturday-02 February-2008 (you get the idea)
