Bản Ilauncher mới dùng rất thích. Mình giới thiệu qua với các bạn. Nhưng tiếc là "cái ấy" chưa có. Ai mà có thì xin chia sẻ với nhé.
* Four different display modes: Tabbed, Sliding classic, One tab display and No tabs
* Add icons to each of your tabs for a much better looking display
* Customize shortcuts order and size. Support both large shortcut icons and small shortcut icons
* Add meters to tabs: Memory, Battery, File Store, SD Card, CF Card and backup battery
* All of iLauncher icons support both regular BMP files and TGA files. Display TGA icons with half-transparency levels for a better look on various today themes
* Create tray icons tab to display shortcuts on your device bottom tray bar
* Easier browsing to your files with links directly to common folders on your Pocket PC
* Rearrange, add, remove, and name tabs
* Add shortcuts to control panel applets
* iLauncher can be installed on main memory, built in storage or storage card, keeping memory usage in mind. iLauncher core dll is only 200kb!
iLauncher display
* Set up your shortcuts in tabs for any purpose, viewing icons ordered in lines
* Create shortcuts to your favourite programs, documents or control panel applets
* NEW! Create shortcuts directly to your favourite folders!
* Tabs can be displayed on top or bottom; When the number of tabs is larger than window width two scroll buttons will appear on tab sides
* Optionally add direct links to control panel screens from iLauncher tabs
* Add meters for Memory, Battery, File Store, SD Card etc., supports both small and large icons
* Tap and hold a link will popup a tooltip with the shortcut name
iLauncher display
