IndiBar 2.0
huydn25
IndiBar 2.0
Summary: The compact system utility. Start Menu, Task Manager, System Indivators, Brightness regulator
Task Manager allows to operate the started application (Switch, Close, Close all, Close Incative)
Task Panel it is show and switching of active application in the top bar
Start Menu. Flexibly customizable menu
Tools allows to adjust backlight and to look through the system information
Indicators. Flexibly customizable indicators of a charge of the battery and operative memory
Close button - replaces the button of closing of the active application
Shortcuts allow to assign the basic functions to hardware buttons
Flexibly customizable position and tap policy
QVGA/VGA support
WM2003/WM2003SE/WM5 compatible
Link test
http://www.pocketgear.com/software_detail.asp?id=23272
