Kaspersky Lab KMS9 v9.4.95 S60v3 v5 S^3 SymbianOS9.x Signed bẻ-KroliX
Trunghuy90
Kaspersky Lab KMS9 v9.4.95 S60v3 v5 S^3 SymbianOS9.x Signed Cr@cked-KroliX
Kaspersky Mobile Security 9.0 is aimed at providing comprehensive protection for mobile devices.
The product provides the following options:
* scanning of the file system for viruses and other types of malware on demand or according to a preset schedule;
* antiviral scanning of files on access;
* quarantining of infected files and the remedying of some of them;
* updating of databases on demand or according to a preset schedule via GPRS-Internet, Wi-Fi, EDGE or ActiveSync (for the Windows Mobile version);
* blocking of unwanted SMS’s and calls;
* blocking of the user’s data if the device is lost or stolen;
* deletion of the user’s data if the device is lost or stolen;
* protection of the device against TCP/IP protocol network attacks;
* creation of folders in which to store encrypted files;
* allows the location of the phone to be remotely identified (if the device is equipped with a GPS receiver);
* blocking of outgoing calls and SMS’s to specific numbers;
* allows the temporary concealment/restoration of personal information.
The easy-to-use intuitive interface helps the user to manage the product.
The product is installed in the main memory of the mobile device only.
Product components:
Kaspersky Mobile Security 9.0 includes the following components:
* Anti-Virus
* Anti-Spam
* Anti-Theft
* Firewall
* Encryption
* Parental control
* Privacy Protection
install note :
Set KMS_9.4.95
Start the animation and exit.
We include CapsOFF
Along the path C: \ \ private \ 20028DDF
rename the folder 20028DDF, adding the unit (like so 20028DDF1)
Find settings.kls file and rename it to settings1.kls
Open it in X-plore, pressing the button 8 (hex)
Click Options> Search in hex and enter 3b, there is first rezultat.snova click function and choose to look further. There exists we need the line at 000100 (the first column Hex) it we need. Now, after the values 3b write the first 14 blocks of values, in my case is 46 4e 5a 47 31 28 31 48 57 54 47 4f 40 f7.to we have got 14 pairs of numbers / letters. We write them all where else.
Now just open the file settings.kls, which is located in the archive, click search in hex and look for the same line. We see the following values 3b numbers 58 58 58 58 58 58 58 58 58 58 58 58 58 58 so they need to be replaced by the figures that we recorded the original file.
Replace, save the changes.
Delete the file settings1.kls.
We take our just edited and settings.kls Suppose it on the path C: \ \ private \ 20028DDF1.
Back to rename the folder from 20028DDF1 in 20028DDF
Run Kaspersky
Mã:
[url=http://www.mediafire.com/?eyelmyh5m47alh6]Kaspersky Lab KMS9 v9.4.95 S60v3 v5 S^3 SymbianOS9.x Signed .......-KroliX.rar[/url]
Thank hth2813
Tạm dịch :
Lưu ý khi cài đặt :​
Cài đặt KMS_9.4.95
Mở KM rồi thoát ra .
Bật CapsOFF
Theo đường dẫn C: \ \ private \ 20028DDF
đổi tên thư mục 20028DDF, thêm các đơn vị (ví dụ như 20028DDF1)
Tìm settings.kls file và đổi tên nó thành settings1.kls
Mở nó bằng plore-X, nhấn nút 8 (hex)
Click Tùy chọn> Tìm kiếm trong hex và nhập 3b. Tìm dòng 000.100 . Bây giờ, sau khi các giá trị 3b viết trong 14 khối đầu tiên của các giá trị, trong trường hợp của tôi là 46 4e 5a 47 31 28 31 48 57 54 47 40 4e f7.to và ta có 14 cặp số / chữ cái. Copy nó đến 1 nơi khác.
Bây giờ chỉ cần mở file settings.kls, vừa copy lúc trước, hãy nhấp vào tìm kiếm trong hex và tìm kiếm cùng một dòng. Ta thấy các giá trị sau 3b số 58 58 58 58 58 58 58 58 58 58 58 58 58 58 và chúng phải được thay thế bằng những con số mà ta đã ghi lại file gốc lúc trước .
Xóa file settings1.kls.
Copy file settings.kls đã chỉnh sửa vào đường dẫn C: \ \ private \ 20028DDF1.
Đổi tên thư mục từ 20028DDF1 lại thành 20028DDF
Chạy Kaspersky
Cái này giá mà có cái patch như những bản trước thì hay biết mấy......Mình có cài vào máy nhưng do mình cẩu thả làm sai một bước khiến giờ không sao hack được nó nữa...Nghĩ tới phoọc mát máy mà ngán đến cổ...đợi xem có patch không,dùng patch tiện hơn,đỡ nhầm.Không biết bản này có thêm gì không nhỉ.Minh vẫn dùng bản 9.03.79...
Kaspersky Lab KMS9 v9.4.95 S60v3 v5 S^3 SymbianOS9.x [FreEZer]c1cl0n@FoXPDA
How to use:
1. Install KMS v9
2. Run KMS v9
3. Install runtime v9
4. Install FreEZer v1.0
5. Register your KMS to trial license (7 days)
6. Exit KMV and run FreEZ
7. Enjoy
How to use - Hứớng dẫn sử dụng :
1. Install KMS v9 - Cài đặt KMS v9
2. Run KMS v9 - Chạy KMS v9
3. Install runtime v9 - Cài đặt runtime v9
4. Install FreEZer v1.0 - Cài đặt FreEZer v1.0
5. Register your KMS to trial license (7 days) - Đăng ký sử dụng thử ( trial 7 ngày ) KMS
6. Exit KMV and run FreEZ - Thoát KMV và chạy FreEZ
7. Enjoy - Tận hưởng thành quả
Mã:
[url=http://www.mediafire.com/?1ljd4so9st1dmej]FreEZer_v1.0.zip[/url]
[url=http://www.mediafire.com/?686hu7s2lucbxvc]KMS_v9.4.95.zip[/url]
[url=http://www.mediafire.com/?um89lmdonrdeg39]runtime_s60v3.zip[/url]
Thank 2 anh hth2813 & TanVD Be Yeu
cài crack xong nga`y giờ nó về` năm 1990..
còn hạn sử dụng KMS >7000 NGÀY..
SAU ĐÓ CHỈNH LẠI GIỜ NGÀY 2011 THÌ CÒN 7 NGÀY ... HẠ`...
NÓI CHUNG AI MUN CRACK THÌ CHỈNH LẠI NĂM ...... HEHE ..
Mình không chỉnh lại ngày tháng năm vẫn hack được hơn 7000 ngày....Nhưng khởi động lại thì đúng là nó chỉ còn 7 ngày....chẳng biết sao nữa
Sao mình rename 20028ddf khống đuơc vậy ta.Dù đã bât Capoff mà vẩn không đươc
crack bằng file settings ko đc đâu bạn...
chỉ ctack dc bằng fezen thui.. nhưng phải chỉnh năm về 1990..
nếu chỉnh về 2011 thì con 7 ngày....
chờ bạn crack tiếp theo vậy.
Đồng ý nhưng mà
Đồng ý nhưng mà nếu chỉnh về 2011 thì luôn luôn còn lại 7 ngày
- Nếu muốn F###L thì trước tiên phải đăng ký sử dụng 7 ngày trước sau đó mới dùng đến Cr@ck, nếu mà Cr@ck trước sẽ gặp những trường hợp mà các bạn nói là chỉnh năm 2011 là đúng rồi.
Sao cái runtime không tải được vì chẳng có kb nào hết trời , bạn nào có up lại dùm với thanks .............
