KDSkamal's Universal WM6 beautiful Edition
khoi
Các bạn cùng test bản này xem sao nhé , bản này xuất hiện 30/06/2007 nhưng thấy chưa ai trên PV test cả, riêng mình mới UP nên chưa có nhận xét gì cả
Contents: OS only
Memory after hard-reset..
based on: midget ROM
main memory:35.9MB
program memory:>27MB
Really, I always wanted to get productive instead of flashing my halley berry(my black universal) after every 1h or so. I was spending more time flashing and setting it up.
This ROM is actually for those people who want all the important utilities as a part of OS itself.
Some highlights of this ROM..
*no crap in "my documents": this includes all the useless pics, nonsense sounds
Actually, before this ROM, whatever ROM I used to use, this was the first thing I used to do that is, delete all this crap. yay, this means no "dog bark" sound !!
*It should be clean and usable for business purposes: Clearly, we have invested so much(put more stress on "so much!") on our device. That is why, no crap
*Vista skin for WMP mobile:thanks to Xcillion. This really makes me say, WOW! Infact, this is now the default skin of the ROM. see the second screenshot
*TCPMP: yeah! It is a part of ROM now. So, you save ~1.5MB(yay!)
*no bubble-breaker
*Adobe reader pre-hacked to VGA mode.
See the difference in the first screenshot given below
*Playlist editor inbuilt to the ROM:find it in the "utilities" folder. Now, you can make/edit playlists on the go
*USB HDD:find it in the "utilities" folder
*Pocket RAR:
*no "one note mobile":see the third screenshot. This is no more(anyone used it anyway?)
*soft keys mapped to contacts and adobe reader. The left soft-key says "my contacts" and the right soft-key says "my PDFs". Sounds windows..isn't?
*some really nice and beautiful themes are built into the ROM. I m sure, everybody would like them. See the 4th, 5th and 6th screenshots.
*on the other hand, the ugly looking themes which used to be built into the ROM are gone now. Yeah no guavas and no green theme
*the default ringtone just got changed! The ringtone is soothing now. I extracted it when I had a chance to beta-test the "atom exec"(~1y ago from now). Its lovely. I m sure, all of you will like it. And don't worry, the default WM6 is still there. Just by some other name
*no htc plugin
*no pim backup:accept it! all of us have better backup tools(somebody said, spb backup?)
Just a little request after hard-reset: you gotta manually go to the file explorer>>windows>>start menu>>programs and delete the backup folder from there.
I m somehow unable to delete it
If someone can mirror it, it would be benificial for the community
Tham khảo ở đây
LINK TẢI
lâu lâu up thử bản rom khác xem thế nào nhỉ!
xem chừng bản rom này Sạch quá nhỉ.
đang up thử, test rồi sẽ nhận xét sơ bộ cho các bác tham khảo nhé!
đang dùng bản 10 ổn quá nên chưa muốn test bản này, bro nào cho ýe kiến về bản nay đi
Bản này mình up thử rồi! Rom ổ định.
Phải công nhận đây là bản rom khá sạch.
Giao diện phone đẹp!
chưa test kỹ nên mới chỉ nhận xét sơ sơ vài dòng!
Mới up thử, giao diện cũng tạm (tại trước giờ cứ dùng đồ default nên mất cảm giác đẹp là gì:))). Tuy nhiên vẫn thích bản clean hơn, không thích soft. Vì em dùng để set task và appointment cho công việc nhiều thôi, không cần soft và codec or sth else....
Cho chạy thử 3 tiếng thì thấy cũng ổn về pin và RAM (tất nhiên không như kiểu thường em dùng => super tiết kiệm pin).
Đây làm bản ROM tốt.
Mình cũng dùng thử 2 ngay nay rồi, thấy rất ổn, khắc phục được lỗi không tạo được new account trong Message, ram ít tụt, tốc độ mở ứng dụng nhanh... chưa phát hiện được lỗi nào
...testing...
phải công nhận là bản Rom này tốc độ rất nhanh mà Ram lại tụt rất ít. các soft tích hợp trong Rom là những soft cần thiết. Nói chung là bỏ 1 phiếu Good cho Rom này
Tôi cung đang dùng thử, nói chung cảm nhận thấy ổn định, tương thích hầu hết các phần mềm ưa thích, riêng có phần giao diện Telephone thì có vẻ hơi không đẹp lắm nhưng cái Wimdows media thi giao diên nhìn lại dễ chịu, Ram hơi thấp và cũng có bị tụt chút nhưng chậm có thể chấp nhận được. Tóm lại cũng là một bản Rom hay
Không hiểu sao bản rom này khi up trên con exec thì trống 40M nhưng trên SPV thì được có 36M??? Chẳng hiểu sao đã up đi up lại trên SPV mà vẫn vậy. Ai cho nhời giải thích nào???????? :(:)(:)((
bản này dùng ổn thật, tụt ram thì vẫn có nhưng ỏ mức chấp nhận được, thích nhất là nó chưa thấy hiện tượng treo máy, dùng nhanh và khá ổn định, pin cũng okie luôn, mình đánh giá bản này tốt,
pm: dùng exec nên không thấy lỗi như bác chuhuyhoan, chắc là do phần cứng
ai có link khác k?giúp e với, link của bác Khoi toàn tiếng tàu à???
Đúng là mình kiểm tra lại Bản này trong đó bị xóa rồi , Có bạn nào Reup dùm với. Bản này thấy ưu điểm nhất là rất ít hao pin.
Hay có hai link trên xda-developers bạn thử nhé vì cả hai link này mình không dow được:
Link bác Khôi cho vẫn down tốt mà ,chỉ mỗi tội down hơi châm (chắc là do dùng Free) nhưng thiếu mất voice speed dial cũng hơi đáng tiếc
sau vài ngày test bản ROM này, mình có một số nhận xét sau:
- theo cảm nhận của mình thì bản này ít hao pin hơn so với các bản khác.
- ít tụt RAM
Nếu như trên cơ sở bản này, nhóm làm ROM của pdaviet phát triển thêm thì sẽ có một bản ROM tương đối hoàn chỉnh...
Mình có một số nhận xét sau khi test bản ROM này :
- Bản Rom này ít hao pin.
- Tụt ram thì vẫn có nhưng ở mức chấp nhận được, luôn trên 20M
- Giao diện Windows Media khác những bản Rom của bác Quang
- Rom khá sạch, gần giống bản ROM v2.10.10 CLEAN, tích hợp ít soft nhưng không cập nhật phiên bản mới, cụ thể là soft TCPMP v0.72RC1 lẽ ra nên thay bằng CorePlayer v1.1.1
- Bàn phím và phần giao diện Telephone thì không đẹp bằng bản ROM v2.10.10A nhất là bàn phím.
- Đặc biệt là không có hiện tượng treo máy.
Nếu như được phát triển và chỉnh sửa thêm thì chắc rằng đây sẽ là 1 bản Rom hoàn chỉnh.
mình dùng bản này vẫn bị treo máy ( bị 1 nhát :) ), nhưng công nhận bản này chạy rất nhanh, tuy nhiên về vấn đề skin của WMP và diapad thì mình không thích lắm, nhìn nó không pro
mới up hôm qua, dùng cũng ngon, có mấy cái hơi gét đó là: thay đổi skin hay ảnh nền thì toàn phải soft-reset xong mới thấy; 2 phím tắt với các phím khác khi ấn vào ko tác dụng( vd như 2 phím hang-up và call ở phía ngoài, bt W2005 có thể ấn call là vào chức năng call luôn đc, nhưng ở bản này ko đc). nhạc chuông hơi nhỏ, nhưng windowsmedia có vẻ hay hơn.Ram thấy ổn, pin ngon.
bạn xem lại xem đã xóa hết trong extd rom trước khi up không nhá, vì tình trạng lỗi phím cứng là do không xóa hết trong etd rom mà,
có thể cho mình xin link help về xóa extd rom ko, mình mới mày mò cái này nên chưa rõ lắm, thanks bạn nhiều
