Một vài hình ảnh và nhận xét cá nhân:
ROM chạy mượt dù mình đã set PP về Dynamic,đẹp và nhẹ hơn vì đã được remove nhiều soft không cần thiết.
Tham khảo thêm:
The rom has very long battery life with the radio included!
This rom is compatible with:
- Skype
- IGO
- Every sip you would like to use
What is new:
- Most of the ATI drivers are implemented (still experimental!)
- New final Diamond theme made by Empex
- HTCHome removed
- Diamond keyboard removed
- Ringtone bug solved, ringtones do stick now
- moBluev2_1 (easy configure your Bluetooth with this app!)
I've added from latest Diamond build:
- BTBPP v.1_6_5_0
- BTFTP v.1_2_33281_91
- BTSAP v.3_1_0_0R2
- Concurrence Manager v.1_1_18143521_0000
- DShow v.2_00_080522_0
- EnLargeStartmenu v.1_2_34070_1 (yes you can make the menu small as well!)
- HTCGesture v.1_0_30346_1
- LockStreamDRM v.1_1_080411_O9
- mHub v.6_54_080121_E1
- PictureEnhancement v.1_50_18131521_c2
- Diamond Playshow v.1_0_18151810_1
- RingtonePlugin v.1_00_080416_1
- ShareDLL v.2_0_071002_00v2
- SmartTouch v.1_0_31096_0
- TaskManager v.2_1_34072_100 (Easy to navigate with your finger)
- TouchFLO v.3_0_29946_34
- Videotelephony v.2_0_31227_0
- Voicerecorder v.1_10_18151728_0
- CommManager v.2.1.4.0
- Notifications and sounds from Diamond (L26 customized!)
Customized Diamond apps (thanks to the Developers!)
- Diamond calculator skin (Agamemmnon)
- Diamond WMP skin (Poorlyduck)
Apps included:
- HTC Album v.1.0.1030.720- Camera v.5_04_29195_00
- HTC_AudioManager_1_2_1813.3129
- HTC_Random_Acces - New HTC Endkey (Shortcut in windows dir if you want to asign it to the red phone button using Long_Keypress!)
- HTC_ConnectionSetup_1_0_31758_7
- Arcsoft_MMS_5_0_31_19
- Battery Monitor
- Kaiser_Slidingsounds (with extra sounds)
- Mortscript_4.1.0.5_Longkeypress
- Startup Sound
- Total Commander_ 2.5
- DotFred_Task_Manager_ver.3.0
- RegLogger
- Schap's_Advanced Config
- Esmertec_Jbed_20080222_3_1
- GroupSMS
- HushSMS
- PocketRAR_V.38b1
- QuickGPS__1_00_220821_01
- Rhapsody_Screencapture
- GXMark
- Offcourse my tweaks!
Removed:
- SQM
- WLM
- Windows update
- Winzip
- Voice Command
- Pimbackup
- 1-Calc - HTC_AudioManager_Today_Plugin
- HTCHome
- Gullums Diamond keyboard (to be continued later!)
