Taki7610
Unlock_GSM
ROM Laurentius26_V4_(Base 3.51.502) - Giao diện "Đơn giản - Phiên bản Black " -
Tốc độ khá ổn định - Đặc biệt có tích hợp Tool SCLPC - Giao diện vuốt khá ấn tượng - 1 vài nhận
xét sơ lược ..
Link Tải ROM
P/s : Chuyển qua Bootloader - Khi Tool lấy thông tin device - Tháo cáp và gắn lại cho Tool nhận thiết bị.
Tester : Taki7610
xét sơ lược ..
Mã:
[B][U]INFO : [/U] - [U]Tham khảo thêm :[/U] [URL="http://forum.xda-developers.com/showthread.php?t=389915"]Tại đây[/URL][/B]
Apps included in V4
- Adobe Reader LE v.2.0
- Arcsoft MMS v.5_0_31_16
- Battery_status (Ikarus)
- BCR_World_Card_1_0_070724b
- BT AudioToggle
- BTFTPClient v.1_2_33300_9
- BT_SAP.2.02.b0925.r3
- Calculator (with black skin)
- CallFirewall_ver.1.3
- Cool notification sounds and ringtones
- Comm Manager_Colored (6 button's)
- DualTouch dialer
- DotFred_Task_Manager_ver.2.9
- EnlargeMenu_v.1_1_31503_1
- Fieldtest
- Flashvideobundle v.1.4.4 (04-05 added)
- GroupSMS_v141
- HTC Action Screen_ver.2
- HTC_Album_1_0_1030_720
- HTC_AudioManager_1_2_1017_717
- HTC_Camera_v.5_0_4_2915_00
- HTC ConnectionSetup_1_0_31758_1 [04-05 Updated]
- HTC_Home_v.2.10.1813.3727 [04-05 Updated with new icons]
- HTC Streamingplayer v.3_00_1001_711_00
- HTC_Networkplugin_v.1_0_30468_1
- HTC Quick GPS_1_00_919_717_01 [04-05 Updated]
- HTC_Voice Recorder_v.1.10 (build 130.718)
- HTC_WMPSkin
- Hushsms_c0rnholio (send a 0 SMS)
- Marshall waitcursor (Touch)
- More Kaiser_Slidingsounds
- Mortscript_4.1.0.5 (Configure any key to long press)
- MS Office Mobile
- MS Voice Command (tweaked to work with A2DP and it has incomming call notification!)
- NETCF 3.5
- PHM Notepad
- PimBackup_v.2.8
- PocketRAR_v.3.71b
- Rhapsody_Screencapture
- Realplayer v.1.00 (Build 810.712)
- Regeditor (Part of DF Taskmanager)
- Reglogger
- SDAutorun v.2.0 (UC, User Customize)
- Schaps Advanced Config v.2.1.0.0 (04-05 Updated)
- Schaps_VOIP_Set_v1
- Sipchange
- Slither's CUBE v.0.54 C++ with 3D images (very fast and beautifull!)
- Slueth255_VOIP
- SMS Tweak v.1.0 (04-05 New)
- Sprite Backup
- Sqlcemobile 3.0 [04-05 Downgraded for compatibility issues]
- Startup sound
- SQLCE Mobile 3.5
- TaskManager_v.2_1_33556_1 (BIG BUTTONS AWSOM!)
- Today Agenda_ver.1.1
- Total Commander_ 2.5b3
- TCPMP v.0.81 (04-05 added)
- Windows Live v.10[1].6.31.2600 (04-05 added)
- Windows Mediaplayer (Added Coremp4 codec to watch movies)
REGISTRY Tweaks:
- Autosynchronise time
- Blackberry Connect compatible
- Disable Beam (04-05 added, even more power!)
- Disable Security Warning for Unsigned Apps & Cabs
- Disable Sent SMS Notification
- Disable In-Call Fast Sleep
- Enable GPS Data in Photo Data
- Enable Assisted GPS
- File System Cache
- File System Filter Cache
- Glyph (GDI/Font) Cache set to Large
- Power settings (normal use 3 days battery live !!!)
- Startmenu sounds
- TCP-IP Tweaks
Removed:
- MS Custommer feedback
- One Note
- AT&T PTT (Push To Talk) Support
- Zip (Replaced with PocketRAR)
- at&t Dialer (Replaced with the Touch dual dialer)
- ALL other AT&T
- Windows Update
- Getting started
- SQM
- Intellipad (04-05)
- SMSDirFIX (04-05)
- Adobe flashlite (04-05)
- Query Analyzer (04-05)
Fixed:
- Support for UC (User Customization v.2.0)
- Button 6 assigned to MS Voice Command
- Hold Button 6 assigned to SipChange
- WIFI
- HTCHome new icons
- Startup animation
- Removed WMP shortcut double entry
- ROM is now Skype compatible!
- ROM is now Imaginet Arabizer compatible!
- Touchpal compatible!
- IGO compatible! (disable HTC Home)
- Miomap compatible!
- Folderview in HTCHome
- Replaced Weather .xml
Link Tải ROM
Tester : Taki7610
