Mobile Workstation
hung6310i
Em đang phân vân giữa hai máy Dell Precsion M20 và IBM T41p
Giá cả tương đương nhau
DELL M20
• Centrino Sonoma Intel Pentium M Processor 760 (2.00GHz, 2MB L2 Cache)
• 14.0" SXGA+ (1400 x 1050) Samsung display SXGA+ maximum resolution of 1400x1050 pixels, 16.7 million colors (The M20 graphics chipset supports up to 1600x1200 pixels with external monitor, 16.7 million colors)
• 1 GB 533 MHz DDR2 SDRAM (512MB x 2 SODIMM)
• ATITM MobilityTM FireGLTM V3100 64MB OpenGL workstation graphics
• 60 GB 7200 RPM Hitachi Hard Drive
• Audio type/controller: AC97 (Soft Audio) / ICH3 Stereo: 20-bit stereo-digital to analog and 18-bit stereo analog to digital
• NEC DVD+-RW ND-6650A
• 10/100/1000 Ethernet2 LAN
• Intel PRO Wireless 2200 WLAN (802.11b/g)
• Dell TrueMobileTM 350 Bluetooth module
• Internal 56K Modem
• 6-Cell 53 watt/hour Panasonic battery
• Serial (DTE): (one) 9-pin connector; 16550-compatible, 16-byte buffer
• Parallel: (one) 25-hole connector (unidirectional, bidirectional, or ECP)
• Video: (one) 15-hole connector and S-video out connector
• Infrared: one port compatible with IrDA Standards 1.1 (Fast IR) and 1.0 (Slow IR)
• Audio: microphone-in-jack; stereo headphones/speakers jack
• 4 USB 2.0 compliant connectors
• Modem: RJ-11 port
• Ethernet LAN: RJ-45 port
• 4.88lbs~2.2kg
IBM T41p
* Intel Pentium M (Dothan) 2.0GHz CPU
* ATI Mobility FireGL T2 with 128MB video controller
o 14.1" TFT display with 1400x1050 resolution
* 512MB PC2700 memory standard
* 60GB 7200RPM HDD
* AD1981B AC'97 Audio controller
* UltraBay Slim with the following:
o UltraBay Slim CD-RW/DVD-ROM Combo Drive
* Intel 10/100/1000 Ethernet
* CDC slot with one of the following:
o IBM Integrated Bluetooth II with 56K Modem (BMDC)
* MiniPCI slot with one of the following:
o IBM 11a/b/g Wireless LAN Mini PCI Adapter
o Intel PRO/Wireless LAN 2100 3B Mini PCI Adapter
* (2) Type II CardBus slots or (1) type III
* IBM Embedded Security Subsystem 2.0
* IBM Active Protection System
Nhu cầu của em là làm đồ họa mà cũng hay vác tới vác lui
Giúp em có sự lựa chọn hợp lý nhé các bác
mua T41P đi bạn, dùng ổn định hơn nhiều và cũng yên tâm khi vác đi vác lại
Cả 2 con đều là dòng máy trạm di động, tuy nhiên nếu so sánh với nhau thì không cùng đời _ tức là nếu đem so sanh với con Dell này thì phải là T43P.
Cho nên sự lựa chọn còn lại chỉ là giá cả, nếu bằng nhau chẳng dại gì lấy IBM t41P ( giá thị trường đang khỏan 900 usd trở lại )
