ducdl2
Software version
GSM Radio: 1.65.20.29
Protocol version: 25.88.40.04H
CE version: 3.55.502.1
OS build: Windows Mobile 6.1 AKU 1.0.4 Build 19214
Issues fixed
Attempts to open IMS APN twice before falling back to WAP
Does not reactivate IMS APN after connecting to PC/Activesync
Standby mode, the screen wakes up with a blank screen.
In idle mode "Get AT&T Navigator" keeps blinking.
Backlight turns on and off seemingly randomly based on having email client (MS Direct Push or BBC tested with same results)
Sends RTP packets receiving video
YONA and Proxy Manager
Does not use as high a codec rate as required for VSC
Sends empty RTP packets when streaming
H.263 bitstuffing causing video quality issues
Receive / terminate an incoming call with the phone while streaming music
Option to turn VSC service off changes back to on after a power cycle
Does not properly display video sender/recipient number in VSC UI.
Device with non-camera hardware still prompts the user to initiate a Video Share session
Approximately 1 out of 32 IMS authentications fails due to HTTP digest implementation bug
Device does not re-read the IMS public user identity file on REFRESH.
Reopens IMS APN after receiving a 403 response to IMS registration
Time Zone: the time zone is not correctly set when the device is first setup - it defaults to eastern
VSC: Does not maintain IMS registration overnight
Did not attempt to register to IMS after re-opening PDP context
Does not perform IMS deregistration when powering down or entering flight mode
Incorrect authentication settings used for ims.cingular APN
Will not reconnect to IMS after exiting flight mode
Links:http://rapidshare.com/files/122290549/RUU_Kaiser_CINGULAR_WWE_.exe
http://www.megaupload.com/?d=S436Z0PJ
Các bạn Test thử nghe.
Issues fixed
