[New Build - v4] Uni WM6 Pro - 5.2.1921 (Build 18578.0.7.0) của Ranju
linhlk
Ranju tiếp tục ra bản mới,mọi người test thử xem sao=D>=D>=D>
Một vài thông số của bản Rom:
There is a new core ported, I suppose this is the first build of 18578.0.7.0 for our Universal. :)
I tried to keep it vanilla (as usual) and only most needed tools have been incorporated to the build.
The most features and usefulness of v4 (18578.0.7.0):
-- Removed SQM
-- Removed OneNote
-- Removed Windows Live/Live search
-- Removed Auto Update/Approve Update
-- Added pBar 1.4 (by nncuong) Task manager [with little cosmetic update by me]
-- Added WM5torage (USB HDD Emulation)
-- Added PocketRAR 3.71 (with .zip/.rar association)
-- Added Adobe Reader LE 2.0 (optimized)
-- Added OxiosHibernate 1.3 and Performance/overclocking applet
-- Added a light-weight Birthday today plugin
-- Bluetooth Car-kit SIM access
-- CompactFramework 2.0 SP1
-- New Bluetooth Stack
-- ArcSoft MMS
-- STK srvice, SIM Mamager and all common applications
-- SMS delivery fix (by Saman)
-- New ComManager (9-button)
-- Voice notification (interesting!)
-- SDHC driver (by mamaich)
-- SD block transfer size set to 256k (for HQ video playback)
-- Default GSM mode set to "GSM" (to save battery) [it can be changed from phone setting]
-- Set default search to Google (desktop) search
-- Default favorite added: Google, Gmail (desktop) and XDA-Developers - Universal
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Improved device wake-up from sleep (before alarms)
-- Registry-type set to file-based; it will help not to forget the settings made by the user
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Today item set to hidden of "Messaging", "Wireless" and "Keylock" (Unhide from Today settings, if needed)
-- Default notification type set to "Visible + Beep"
-- Unlock/Unhiding tool for extROM
-- Few other bug fix / tweaks
-- New boot splash
-- Should work on G3/G4 both devices [No Flash Disk]
Các bạn tham khảo và down theo link sau nhé
http://forum.xda-developers.com/showthread.php?t=328576
bản này hiện vẫn chưa hoàn chỉnh lắm, bị lỗi wifi WPA ko connect được, phím backlight mặc định ko sử dụng được, bị GSM crash ngay khi vừa up xong, đành quay lại với bản 2.12.04 của Jwrightmcps
MẤY BẢN ROM TRƯỚC CỦA RANJU TỐT VÀ ỔN DỊNH LẮM MÀ SAO BẢN MỚI NÀY NHIỀU LỖI THẾ NHỈ?
Dùng Rom của RANJU phải công nhận là ổn định và độ tin cậy cao, bản mới này tôi cũng đang dùng thử, cảm nhận thì cũng như bản trước đó nhưng có cái lạ là khi cài các sót vào Storage thì cứ phải xóa phần đã có sẵn trong đó đi thì cài mới được, thậm chí thỉnh thoảng cò phải SR nữa, bản trước không như vậy, ngoài ra mọi thứ khác tôi thấy bình thường, không cảm thấy thay đổi gì đáng kể.
