Taki7610
Unlock_GSM
![](http://i988.photobucket.com/albums/af7/luanhongha/TV_zps3a594519.jpg)
Mã:
Number of Image Files: 1
Processing Image File :
rm724__08.79.ppm_v
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 0280040784092828
Original Product Code: 059F9X0
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_32436.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_CERTIFICATE_4FF50F7F.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355512055410265\355512055410265_PMM_PROT_226D4F33.bin
Security Code: 12345
Data Sections : 01
Current File : rm724__08.79.ppm_v
Compile Name: package_v.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 6235544 Bytes
Sending Certificate Block
PPM Certificate Block Sent Successfully...
Processing Section 01
PPM Erase Block: 0x41B40000~0x4223FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 6232200 bytes
Data Checksum: 170D
Uploading Data Blocks to phone...
Block Write Successful...
PPM Data Blocks uploaded to phone...
Data Verification Successful...
Total Flashing Time (Erase + Flashing) : 00:00:25
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 08.87 17-10-12 RM-724 (c) Nokia
IMEI Plain : 355512055410265
IMEI Spare : A355512055410260
IMEI SV : 33555120554102617F
Phone Model: K C2-05
Category : Entry Phone
Phone Type : RM-724
Extended Phone Information
Product Serial Number: B41A941BI
Product Code : 059F9X0
Module Code : 0204807
Basic Production Code: 059D2P1
Long Production SN : 0
PPM SW Version : V 08.79 17-08-12 RM-724 (c) Nokia V
BT MCM Version : 19b5-22012
MCU SW Version : V 08.87 17-10-12 RM-724 (c) Nokia
HW Version : 2001
RFIC Version : Dummy RFIC version
LCD Version : TPO
Content Pack Version : Content: a_dgray_059F9X0 V 08.87 17-10-12 RM-724 (c) Nokia
Bluetooth ID : F4:F5:A5:96:32:92
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 01022C00
DCC Ver: 003005
Status : OK
Selected VPL File:
RM724_059F9X0_08.87_038.vpl
Variant Details : RM-724 EURO A DGRAY LATIN DK
Software Version : 08.87
Product Type : RM-724
Variant Version : 038
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
