Taki7610
Unlock_GSM
Mã:
Number of Image Files: 2
(Mass Memory File Detected)
Processing Image File :
DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin
CMT Type : MAEMO/MEEGO
DFL61_HARMATTAN_40.2012.21-3.280.1_EMMC_280.bin
C:\AdvanceBox Turbo Flasher\Logs\flasher.exe
-F DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin
C:\Program Files (x86)\Nokia\Phoenix\Products\RM-696\
-F DFL61_HARMATTAN_40.2012.21-3.280.04.1_PR_LEGACY_280_ARM_RM-696_PRD_signed.bin -F DFL61_HARMATTAN_40.2012.21-3.280.1_EMMC_280.bin
BB5 MEEGO / HARMATTAN FLASHER
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
TIPS & INFORMATION:
1. To Turn OFF the Phone, PRESS and HOLD the POWER
button for at least 10 Seconds...
2. Battery Charging will still work on "DEAD" Phones.
3. Factory Reset will make Flashing 15 minutes longer
and it will Totally Erase the User Data and Remove
the Phone Lock + Security Code as well...
4. Skip ADL Chk will Cold Flash the Device.
Waiting For Phone on USB PORT/s...
REQUIRED MODE: BOOTROM MODE
Sending PRIMARY-BOOT: SUCCESSFUL!
Sending SECONDARY-BOOT: SUCCESSFUL!
SECURE USER DATA ERASING IN PROGRESS
Secure Data Erasing takes about 15 MINUTES...
DO NOT DISCONNECT THE PHONE!!! JUST WAIT...
Estimated time to Finish Erasing: 19:51:20 (24-h Time Format)
Battery Voltage Test: PASSED
Ready to Flash Images to Device...
Processing Image: cert-sw
Processing Image: cmt-2nd
Processing Image: cmt-algo
Processing Image: cmt-mcusw
Processing Image: xloader
Processing Image: secondary
Processing Image: kernel
Processing Image: rootfs
Processing Image: mmc
All Images were Succssfully Uploaded!
Software Update Done
[]: Found 1 active devices.
[Nokia N900 USB Phonet]: Opening Connection
[Nokia N900 USB Phonet]: Port opened OK!
Rebooting Phone...
Total Flashing Time (Erase + Flashing) : 00:19:38
(Booting time is NOT Included)
Phone is not Connected OR it is not in the
Required Mode...
Reboot the Phone and Enable "PC Suite" Mode
Life timer data is not yet used...
Life timer: ----:--
