NokiaCooker BETA - Tool Cook ROM for S60v3|v5
jinsk8r
NokiaCooker BETA - Tool Cook ROM cho S60v3 - S60v5
Tool đã có nhiều nhưng cứ post lên cho ae xài thử, ai thích cái nào thì xài cái đó. Tool này hỗ trợ cả S60v3
Now it is possible to edit ROFS and UDA easily, using drag & drop.
CORE and image can't be repacked yet!
ROFx image can be repacked, but it HAS NOT BEEN TESTED YET!
PLEASE NOTE: this tool is very easy to use, but it is always a tool for experts and smart people, it is not for everyone!
If you remove or replace some critical system component, your phone will dead at 100%, you have to know exactly which is the purpose of the files that you remove/replace!
ROFS Size: It is not safe to augment the ROFS size because it could brick your phone.
For this reason, NokiaCooker will show you an error message in case that the original ROFS size has been augmented.
So, you add new files to the ROFS, you'll have to delete some other files, to properly repack the firmware.
For the UDA, there isn't any size problem.
Changelogs:
0.4.3
- Improved: Log Window can be resized
- Improved: The OBY is created trying to keep the same file order as in the original firmware.
- Fixed: Warnings raised from the RofsBuild.exe command will be shown in the log window and the repack will complete successfully. If the RofsBuild.exe raised an error, the repack will not be completed.
0.4.2
- Fixed: Some ROFS file were skipped during the Rebuild if the file was in a very long path like:
"C:\Documents and Settings\Root\Desktop\NokiaCooker BETA 0.4.1\Files\private\10203636\security\trustroots\device\certificates\TMO_trusted_third_party_certificate.cer"
0.4.1
- Improved: Shows warning messages raised from the RofsBuild.exe command
- Improved: ROFX Rebuild
0.4
- New: FAT32 file-system is now supported. (X6 UDA is in FAT32 format)
- New: Extension Column in the grid. So you can easily remove unneeded languages files from the ROFS
- New: Experimental ROFx support... It should work but NEEDS TO BE TESTED!
- New: Automatically creates a Backup File when repacking firmware.
- Improved: FAT Detection
- Fixed: ROFS Rebuild for N97
TẢI
bạn ơi! bạn đã cook thành công rom cho s60v3/v5 chưa vậy?
Nếu đã thì có thể share cho tớ một chút kinh nghiệm được không?
SDT của tớ: 0984913969
Được hay 0 thì cũng thanks bạn nhiều nha!
