OMNIA CUSTOM ROM DXHL2 pack with Adobe Flash Lite 3.1/.NetCF 3.5/Chinese
tuanbka
Please, follow this update! There is no removal of any original apps from the rom, so you can enjoy the cool Omnia environment!
!!!USE CUSTOM ROMS AT YOUR OWN RISK!!!
!!!CUSTOM ROMS CAN HARM YOUR DEVICE!!!
!!!CUSTOM ROMS CAN CANCEL YOUR DEVICE WARRANTY!!!
!!!ATTENTION!!!
After you updated the firmware, when your phone restarted, and you finished calibrate your phone, check the following:
The Start-panel and Action-panel must has orange headcolour!
If it is gray, the original firmware was downloaded/extracted incorrectly, it cause a several error on your phone!
25.12.2008:
Marry X-mas!
* updated Opera, now it rocks!
* Added Chinese input (only takes 2MB, so it wont be removed / You can delete \Program Files\PlumSIP6 to free up this space) cool.gif
* Free disk space: 47 MB (because of the new!!! samsung apps)
* Gypsii communication
* Google Maps
DOWNLOAD: Firmware Compressed 7z file: 97 MB
Mediafire link http://www.mediafire.com/?7mcgmatjwmx
Rapidshare link http://rapidshare.com/files/177413542/i900-HL2_0136-NIA-HL2.7z.html
12.12.2008:
* Performance optimization + registy cleanup(I hate it... )
* Professional task manager included (press about and check its homepage for further info)
* Google stuffs are removed (you can install them to the internal large storage Google Maps)
* Audio volume is still optimized for high quality digital audio for wire headsets
o After the first boot, set lower the volume sliders!
o There are lot of type of bluetooth headset that are really sensitive, so use \windows\soundtester.exe for its optimization
o With wire headsets you can still enjoy really loud and clear digital audio
* Free disk space: 65 MB
03.12.2008:
* PHONE: DXHK1 rom inserted (GPS, VIDEOCALL, WIFI performance is improved a lot!!!)
* only .NetCF 3.5 rules your applications (2.0 files are removed because they aren't in use now)
* .Net Configurator is added, so if you install any older or newer part of .NetCF, you can tell to your .Net apps to select the best version for itself
* only Adobe FlashLite 3.1 rules your browsers (2.1 files and its components are removed)
If you installed macromedia flash 7, and removed it, it will totally destroy your flash registry part, so after use the attached cab file to restore flashlite 3.1
* system was compressed for more physical free storage space (without any file remove)
* Use the Adv Config Tool: set PERFORMANCE (see attached image) MUST BE!
* Free disk space: 64 MB
30.11.2008:
* Audio Volume optimization (At first time, it boots up maximum volume, so set it lower, and enjoy the real clear digital audio with your Omnia )
* Advanced Configuration Tool 3.3 is included (you can set a lot of things with it like power management and phone/pda personalization)
* ClearTemp 1.1 is included (you can free up disk space with it)
* nueStorageManager CPL v1.1 is included (mounting, formatting, defragmenting volumes)
*You can find it in Control panel under System
*Backup all the data from your DSK3 INAND drive (8GB / 16Gb storage)
*Dismount DSK3 INAND with this tool
*Click on Properties, and Dismount volume, and Format
*Turn the TFAT on, Quick format off
*Start
* This is important for safety reason, TFAT has 2 fat table, WM could recover the whole partition automatically
* File Explorer extension to make the default file browser to professional
* HTCApi, HTCSensor and opengl files are included (you can use HTC apps now on your Omnia)
* Microsoft Windows latest updates for WM 6.1
* .NETCF 2 / 3.5 are included
* PPCPimBackup can backup your phone data, and can restore it easily
* Adobe FlashLite 2.1 and FlashLite 3.1 is included (you can use Samsung apps like widget, while you can browse flash pages with Opera )
* Free disk space: 55 MB
Nguồn: http://www.modaco.com/content/i9x0-...476/samsung-i900-omnia-custom-rom-27-12-2008/
:p
I cannot download form RapidShare. it show as blow:
Error
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
This limit is reached.
To download this file, the uploader either needs to transfer this file into his/her Collector's Account, or upload the file again. The file can later be moved to a Collector's Account. The uploader just needs to click the delete link of the file to get further information.
Thanks bác đã share cho anh em,
Mình đã down và up rom này bên Modaco gần 5 ngày nay. Tình hình chung là chạy khá ổn như nghe nhạc, FM, sms, truy cập web qua opera, widget,.. đều khá tốt và không thấy bất cứ lỗi gì.
Duy nhất là bộ nhớ có không nhiều thôi, sau khi up xong cài font TV thì bộ nhớ trong chỉ còn 33mb, ram còn 52mb tạm ổn...
Thanks a lot and waiting for new update rom from modaco website!!
Công nhận ROM này dùng ổn.Mình thích cách không remove mà chỉ tinh chỉnh cho tốt.Để lại còn nhận ra là i900 chứ không phải máy HTC.Đã có bản mới hơn chỉ bị lỗi để online widget trên ổ cứng nên nếu chọn ổ cứng làm ổ usb storage thì lỗi widget thôi.Nhưng không đáng ngại.
....Mình thích cách không remove mà chỉ tinh chỉnh cho tốt....
Nếu không remove ra thì làm sao tinh chỉnh cho tốt được.
Một số lượng khá nhiều files "rác" nằm trong \Windows, do sau khi HR/up ROM zin thì được copy vô thư mục con (như các files của Opera thì copy vô Application Data, 1 số lượng files .png vừa nằm trong \Windows\Inbox, vừa nằm trong \Windows...). Office không thường xuyên sử dụng mà có thể cài ra My Storage/Storage Card, Keyboard sẵn có ko gõ tiếng Việt được, lại phải cài thêm. Rồi những chtrinh chẳng bao giờ xài tới... Video Call ở VN hiện có xài được đâu. Khi nào nhà mạng cho xài thì ta lại chép vô hoặc cook lại.
Rồi lại phải cài thêm nhiều chtrinh cần sử dụng. Rất nhiều chtrinh đòi hỏi copy files vào \Windows
Số lượng files trong \Windows càng nhiều thì hệ thống càng chậm.
Khi up 1 ROM clean thì cần biết là ROM đã remove những gì, rồi ta sẽ cần những gì để chép/cài vô lại vào chỗ thích hợp (dĩ nhiên là thực hiện chép/cài auto càng tốt). Nhiều điều còn để nghịch với phone lắm.
Thôi thì coi như những quan điểm khác nhau của người dùng phone WM vậy.
Vâng em cũng thấy rất nhiều file rác ( chẳng có ý nghĩa gì chứ đừng nói là soft )
Dường như các KTV của SS ko quan tâm đến vấn đề làm sạch nó mà chỉ thiết kế chương trình mới mà ko quên ko xoá những cái thừa đi
Sau khi find trong thư mục windows em thấy có thể xoá đi tầm 20-30mb ko cần thiết
mà ai biết cách xoá các file ROM chỉ mình với nhé ( xoá trên PPC ấy )
Một phần chắc là do thiết kế kỳ cục của MW, hoặc do có những khó khăn trong thiết kế ROM từ đầu (chẳng hạn ko thể tạo cấu trúc cây thư mực sẵn trong ROM). Các file ROM phải nằm trong \Windows trước, sau đó các thư mục con mới được tạo và file sẽ được copy vào đúng chỗ cần thiết.
Đúng ko ta?
Ngoài ra còn có sự ẩu tả của những người làm ROM, làm soft. Chuyện này thì chắc là cũng thường tình thế thôi :D
Dễ ẹt, sử dụng soft có tên cooked-ROM :p
Hi all,
Bên modaco đã update rom này ngày 29/12 vừa qua và đã bỏ một số rác như các bác yêu cầu nên bộ nhớ đã tăng lên 71mb nên chạy khá ổn.
Rom trước bị lỗi nhỏ mà mình không phát hiện là thay theme xong thì bị treo máy, đến bản này họ đã sửa lại. Nguyên văn chỉnh sửa, update rom này mình để bản tiếng anh ở đây cho anh em tham khảo:
- When you change from OnlineWidget today item to another one, sometimes the system hungs up. ***FIXED***
- When you try to change the desktop background, sometimes the system hungs up. ***FIXED***
- System files are rearranged to gain more free internal storage memory without any file-removal operation! wink.gif
- Download seperately PlumSIP6 (Check back later please!) Chinese Samsung keyboard: Compressed 7z Archive: 1,2 MB
- Free disk space: 71 MB (and you can still enjoy all the orig apps)
Bản này vẫn đầy đủ đồ chơi cần thiết của con Omnia và sau gần hai ngày chạy thì mình thấy cũng khá ổn, nhất là bộ nhớ đã nhiều lên...
Mong các bác cho thêm ý kiến đóng góp đặc biệt hai bác t2008 và tuanbka.
Các file rác.... được loại bỏ nghĩa là tinh chỉnh.Còn remove là bỏ hẳn đi.Hai cái đấy khác nhau.Mình thích cách làm ROM của bác này là cố gắng giữ lại những soft của SS,chỉ thêm vào các cái đã có nhưng mới hơn và chỉnh sửa để các soft đấy chạy mượt mà hơn.Vì theo quan điểm cá nhân thì có dùng hay không dùng thì vẫn thể hiện tí chút i900 chứ không phải WM nói chung hay HTC.
Còn ROM clean thì trên quan điểm là lấy lõi,rồi add thêm cái gì người cook thích vào thôi.
Không thể bảo cái gì hay hơn,chỉ tùy người dùng và kiểu máy để dùng.
Các file rác có loại là rác thiệt, có thể bỏ khỏi ROM. Các files rác như mình đã nói (do cách làm ROM của WM) thì không thể loại bỏ nếu không remove ra và cài lại bằng cab. Ví dụ trong DXHL2 gốc, Opera9 có 102 files rác chiếm khoảng 4.5MB, SamsungOnlineWidget today có 68 files rác chiếm khoảng 15.0MB. Một con số không nhỏ so với bộ nhớ main memory của i900. Số lượng chừng đó files rác cũng làm cho việc duyệt thư mục Windows chậm hơn.
Quan điểm của mình là 1 ROM clean + auto install các files cab (được tạo từ các soft đã loại ra) thì vẫn tốt hơn, phục vụ được chuyện 9 người 10 ý hơn. Sự tùy chọn của người sử dụng muốn có các soft như i900 gốc tới chừng nào thì tùy họ.
Mỗi người Cook hay Build ROM cũng như sử dụng máy có quan điểm riêng.
Clean ROM cũng là tốt, tuy nhiên Clean cũng chưa chắc đã làm máy chạy nhanh và ổn hơn đâu.
Khái niệm "Clean" tốt nhất là Clean phần registry kia. Registry tốt, sạch tự nhiên máy chạy sẽ nhanh và ổn, kể ra Storage còn thấp. Hơn nữa việc Relock các Module cũng rất quan trọng.
Xóa bỏ các ứng dụng và cài CAB không phải ai cũng thích, chỉ những người thích cài đặt và tin tưởng vào CAB tốt mà thôi, còn những ai chỉ thích dùng PPC như 1 phương tiện PDA thì việc cài đặt quả là việc vất vả. Hơn nữa 1 số ứng dụng cơ bản như MSOFFICE, Opera, Youtube,... cài CAB đôi khi rất hay lỗi xảy ra.
Đặc biệt các ROM Manila2D thì việc cài CAB làm giảm mất khoảng 40% tác dụng của nó. Manila2D đưa vào Build sẽ đồng bộ tốt hơn với hệ thống hơn là cài CAB.
Đó là 1 số kinh nghiệm sử dụng của bản thân mình, không chỉ trên i900.
Với mình, 1 ROM quan trọng ở tốc độ, sự ổn định và tất nhiên phải là những Build và XIP mới nhất. :D
Lựa chọn còn lại là của người sử dụng.
Về nguyên lý có thể CLEAN ROM cho i900 tới xấp xỉ 170-180Mb và RAM tới 75-80Mb sau khi Up ROM là điều không khó.
Nếu dùng trình nén khác, có thể cho Storage cao hơn nữa.
ĐÚng rồi,ngày xưa dùng miniS mà cài các soft của HTC bằng cab toàn khiến máy chạy chậm nhưng sẵn trong ROM thì rất mượt mà.Trước ROM 128 thì sợ hết,giờ toàn 256,để trên 40M sau up là dùng thoải mái rồi.
Tóm lại,tùy sở thích từng người.Quan trọng là dùng tốt,không lỗi,tốc độ đảm bảo theo yêu cầu là được.Thiết bị trợ giúp cá nhân chứ có phải cộng đồng đâu.:))
Lý do rất đơn giản cháu ạ.
Bởi khi chạy BuildOS, trình này có chức năng sắp xếp lại các Module (dll, exe,..) vào ROM khoa học và chính xác hơn là ta cài đè bằng CAB.
Khi Build ROM đọc Maps các bạn sẽ thấy rõ.
Nhất là với các trình chạy song song cùng hệ thống.
Đúng là rom clean không hẳn máy chạy nhanh hơn và ổn định hơn. Mọi người xài PPC cần nhất là tốc độ.
Mình đã từng cài nhiều bản rom clean (phải gọi là rất clean hihi..) và chưa thật sự hài lòng rom nào cả.
Cám ơn những người đã làm ra những bản rom để chúng ta có dịp thử.
Mình đã up thử bản rom này và đã up lại bản V11 của Chú PhamQuang mới cook nóng hỏi vì bản này không đáp ứng được như cầu tai nghe Bluetooth của mình (hay treo). Vấn đề khác mình chưa test.
Vâng, em đồng ý là clean chưa chắc đã làm máy chạy nhanh hơn. Nó chỉ tạo điều kiện thuận lợi cho người dùng thích làm gì thì làm.
Nhưng 1 hệ thống mà quản lý 1 thư mục quá nhiều files với 1 hệ thống cũng chừng đó files nhưng để ở nhiều thư mục khác nhau thì hệ thống nào tốt hơn?
Nếu 1 bản cab làm đúng thì khi em nghĩ chẳng có lý do gì nó khác với bản nằm trong ROM. Nếu có chăng thì do nó bị phân mảnh khi chép vào. Không rõ có trình nào để defrag không?
Cái này thì em cũng không hiểu lý do. Thật lạ. Em không có cơ sở nào để lý giải được vì sao? Em chưa cài Manila2D vào máy từ sau khi cook ROM. Sắp tới hy vọng sẽ thử vụ này xem.
New new, Cũng do bác này cook cho anh em bên Modaco dựa trên bản rom mới nhất là DXHL3, vẫn trên nguyên tắc là giữ nguyên các soft & app của Samsung và bộ nhớ dư ra là 73mb. Gửi văn tiếng Anh gửi các bác tham khảo :
* Desktop is frozen after the background or the theme was changed and Onlinewidgets is activated with active Internet connection ***FIXED***
* Omnia PHONE driver improvements (Battery, Touchscreen, GPS, WiFI...)
* Samsung Application improvements
* Free disk space: 73 MB (and you can still enjoy all the orig apps)
Hiện mới dùng được 1/2 ngày chưa thấy lỗi gì.
Link đây:
http://www.mediafire.com/?sharekey=e1664852dec431dcd2db6fb9a8902bda
or http://www.4shared.com/file/78687025/5172c363/i900-HL3_0137-NIA-HL3.html
Tết, tết đến rồi!!!
Đã có bàn DXHL3 final,mình dùng 2 ngày nay thấy ổn định và pin tốt.Bác nào thích ROM theo phong cách này thì up thử.
21.01.2009 (DXHL3 FINAL):
* New power profile: 35% longer battery
* Free disk space: 82 MB (without removing files)
4shared
Rapidshare
