Oplogo Modder 3.20 by gabika and axivxi
gabika318
!!!UPDATED!!!
Oplogo Modder 3.20
by gabika & axivxi​
Installation:
First install Oplogo Modder (Only Program), then update it with Oplogo Modder (Only Files).
Description:
This app Hide or Mod your phone operator logo.
Choose mod and select OK
Choose name and select OK
Please wait.....
PS: W960-P1-G900 phones use: Activity Menu ON -> Settings: Control Panel - Device - StandBy Application - Activity Menu and SAVE
Functions:
M600 - date,hide,hideall,keylock,mainmenu,timer,original
W950 - date,hide,hideall,hide logo-date,hide logo-time,keylock,timer,mainmenu,original
P990 - date,hide,mainmenu,timer,original
P1 - date,hide,keylock,mainmenu,timer,original
W960 - date,keylock,mainmenu,task,original
G900 - date,hide,mainmenu,timer,original
Supported PHONE Language:
UK English [RSC]
Hungarian [R17]
Russian [R16]
Deutsch [R03]
Polish [R27] NEW
Versions:
1.00
- Only M600i phone
1.10
- M600i and P1i phones
1.30
- Support W960 and W950 phones
- Added M600 Main Menu link and Keylock
1.35
- FIX "ErrPathNotFound: Path not found" error message [was very complicated...]
1.50
- Support G900 and P990i phones
- New M600 option: HideAll - Pic: http://images.netbag.hu/20081020/09241342600.jpg
1.55
- Added P990 Hide option
- Small bugfix
2.00
- Added G900 Hide option
- Multilanguage started: Support Hungarian phone language
- Small bugfix
2.05
- Added W950 Main Menu option [many thanks to chaoscreater]
2.30
- Support Russian and Deutsch phone language
- New W960 options: keylock, task, date
- New W950 option: hideall
- Small bugfix
3.00
- Totally reprogrammed
- Bypass phone selecting section
- Add ALaunch editor (Maximum 10 characters, English language only)
- Improve performance (Up to 70%)
- Add error handler
- New & easier UI (User Interface)
- Add Help & Version History
3.10
- Add other languages (HU, RU, DE) to ALaunch Editor
- Small bugfix (Thank to shahram)
3.20
- Add Polish language
- Support G900 new R6K842 firmware
- Small bugfix (Thank to SEMPITERNAL)
!!!USE Caps Swith OFF!!!
!!!USE LATEST FIRMWARE!!!
!!!Please read Help before use!!!​
* If StandBy menu crash: Please start task manager, run Oplogo Modder, Select .... Original option!
* Report any bugs (related to the program not the moded files), elglish problems, ...
* Please test, and send me feedback!!!
* Working G900, P990, or other phones HEX Code for Oplogo send me or write here!
hehe, cuối cùng thì PV cũng có một nhân vật tầm cỡ thế giới tham gia Post bài. Vui quá :O
PS: Bản này bổ sung thêm chức năng tự động thay đổi tên logo mạng rất hay đấy các bạn ^ ^
Extract here,have 2 file...what it intall? sorry for my bad english !!! ^^
Bạn có thể nói rõ hơn về tự động thay đổi llogo mạng được không. Mình không rõ. P1i sử dụng có tốt không, tại mấy bản trước thấy bị lỗi nhiều quá nên mình chỉnh Hex cho nó an tòan
Welcome to Pdaviet forum, gabika18!
We are proud to have one of the Professional member form persian-forum here.
Registering and posting in Vietnamese based web page are not easy at all. However, you did it. Great effort, mate :)
Waiting for more usefull posts from you...
Thank you and Rep+ added.
However, Gabika, please shorten your post, because it will be sticked at the begining of every page. If it's too long, there will be not enough space for other posts.
I suggest that you delete some of the empty rows, and ormit the old versions history, or include them in a readme.txt file.
Regards,
Anh install file sis Oplogo Modder (Only Program) trước sau đó thì install tiếp file SIS Oplogo Modder (Only Files) là Ok.
Mình ko dùng P1i nên ko dám khẳng định là có chạy tốt trên P1i hay không nên bạn thông cảm nhé. Ngoài ra thì mình có nói bản này có thêm chức năng hỗ trợ sửa tên Logo mạng trực tiếp theo ý mình muốn tức là bản nãy hỗ trợ tự động thay đổi dãy chữ MainMenu trong file Alaunch_loc để có thể thành tên bạn muốn. Bạn có thể xem trên ảnh minh họa nhé.
PS: Ngoài ra tác giả có khuyến cáo là sử dụng cho Firm mới nhất ( thường là dòng GW ) và nếu có sự cố nào ko đúng ý thì phải vào Task chạy lại chương trình và chọn lại Original ( nguyên bản ) để trở về ban đầu. Những lúc bị vậy các bạn nên tránh Restart lại máy để tự chữa mà phải làm theo cách trên.
cái này vẫn thiếu tính năng đặt tên người hay viết chữ thay cho logo mạng! Mình muốn tên mình hiện lên ở chỗ logo mạng vẫn phải sửa bằng hex và bị giới hạn kí tự
Có đó bạn, bạn đã xài thử chưa vậy, mình đã nói ở phần trên là có chức năng mới thay logo mạng theo tên mình thích rùi mà với tối đa là 10 ký tự và chỉ dành cho Tiếng anh.
Oplogo Modder 3.10
Bản Update mới nhất Oplogo Modder 3.10 bởi Gabika 318 & axivxi
Với tính năng mới:
- Hỗ trợ thêm việc sửa tên Logo mạng cho các tiếng Hungari (file .R17)
tiếng Nga (file .R16) và tiếng Đức (file .R03) ( Bản 3.0 chỉ hỗ trợ đổi tên logo cho Tiếng Anh (file .RSC )
- Một vài sửa chữa nhỏ
Ặc, đau thế, rình mãi bản mới nhất, nghĩ là còn rất ít khả năng update (thấy tính năng cũng khá hoàn hảo), ai ngờ vừa cài xong thì ra bản mới, play nhau thế chứ :((>:)
