P535 WM 6.1 Build 21042.1.6.1
đang dùng và hiện tại chưa có vấn đề gì hết cũng không phải cài thêm phần mềm gì nhiều ngoài rescokeyboard ,
Hi,
I have a little trouble with this ROM, or I'm doing sg wrong. This is my third ROM on my P535. Upgrading was always easy and fast.
Yesterday I tried to install the wm6.5 after this ROM 6.1
Downloaded, unpacked, USB inserted , OFF+rec+up+reset pressed as always. But this time an error occured "USB pipe opening error".
I read a few topic about it, but nothing solved this. The same problem when I tried from my notebook. Then I tried to install original Asus WM6 rom via SD card. But there is also a problem: "Failed to copy update files to the device!"
Because upgrade wasn't problem earlier I think that it's caused by this ROM.
Any help would appreciated! Thanks!
Gyurci
i've try this rom many time but i didn't get any problem as you said, i'am just do it by normal way by usb cable and nothing happened , from that time i dowload that rom and using it untill now i up many kind of rom no problem even original rom from asus , let's try again
Today was everything fine, WM6.5 is on the phone. I don't know what was the problem yesterday. ;) Thanks
I installed this ROM on my 64 MB RAM p535 without any problem..
I liked the ROM but because of the SPB pocket plus Thai language, I cant use this rom. why spb pocket plus is only in Thai language..
You can install SPB pocket plus afresh, there can will resolve your language problem 8-|
