Papago! Vietnam 8.2.0 - Bản đồ dần đường Offline dữ liệu VietMap
AquaSta
Moderator
Ứng dụng Papago! Vietnam 8.2.0 thường được gọi là VietMap trên iPhone
$49.99
Category: Navigation
Updated: Sep 06, 2011
Current Version: 8.2.0
8.2.0
Language: English
Seller: Maction Technologies, Inc.
© 2011 Maction Technologies, Inc.
Rated 4+
Requirements: Compatible with iPhone, iPod touch, and iPad. Requires iOS 4.0 or later.
Description
PAPAGO!M8 is Now on your iPhone! The superior navigation software from Maction Technologies can now be installed onto your iPhones!
With the PAPAGO!M8 you can transform your device into a professional navigation system.
IMPORTANT NOTICE & SUGGESTIONS
1.Don't operate the iPhone while driving.
2.If you want to install Papago into iPod touch, be sure that you have the BT GPS receiver.
3.Because of the accuracy of AGPS is not reliable enough, so Papago will not use AGPS signal.
4.If the GPS signal is seperated by the heat reflective shield, the external antenna is needed.
-FEATURES
•Intelligent Search Function
•Simple, User Friendly Interface
•Fast Route Calculation
•Comprehensive Map Data
•No need to Connect to Internet (Wi-Fi/3G)
•Free Map Update
-POWERFUL SOFTWARE FUUNCTIONS
•Multi Navigation Mode: 2D/3D/Split Screen
•i-Fly Touch Screen Interface
•Simulation Inside Tunnels
•Portrait/Landscape Dual Mode Support
•Auto Zooming the Map by Speed
•Day and Night Mode for Display
•Visual and Sound Alarm for Speed Camera
•Built-in 3D Building
•Built-in 3D landmarks
•Junction Views (coming soon!)
-DETAILED MAP DATA
•The latest Vietmap's map (full Vietnam)
FAQ:
Why No GPS signal on iPhone?
1. Please make sure Location Services is switched on. On your iPhone, go to Settings > General > Location Services.
2. Remove the handset restricting if there's any.
3. Some vehicles have a heat reflective shield embedded in the windscreen, which may prevent your iPhone from locating your current position.
4. Your iPhone must be outdoors to locate your current position
Mã:
[URL]http://www.mediafire.com/?r6813mf5cpu16qy[/URL]
[URL]http://www.mediafire.com/?0acjt994sx5voga[/URL]
[URL]http://www.mediafire.com/?qm27lzvoq5mzcif[/URL]
[U]Thank! akaoko[/U]
chào bác, e dơn về rùi nối lại thì nó được thư mục chứ không phải là file ipa, làm sao để cài đây bác??
Mình cài rồi nhưng Font không chuẩn. Các bác chỉ dùm cách fix lỗi. Thanks
bạn bật dịch vụ định vị lên đến khi bắt được sóng vệ tinh bản đồ tự đông chuyển về vị trí bạn đang đứng thôi
