PDAVIET - I8000 WM6.5 ROM (23518.5.5.0) - SB05
Sonblack
Super V.I.P
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.23518 Build 23518.5.5.0 PV
Lời cám ơn - Many thanks:
Admin Kawaguchi (so much for his tools)
Manager PhamQuang (so much)
SM BatKid (so much)
Adv Mod TranMinhMan (so much)
Mod Tom_codon (so much)
Member huyentrangallery (from Samsung, support I8000 for cooking)
Thông tin ROM - ROM Information:
Basic ROM: PDA_I8000NXXJA5_HW_40
Language: Only WWE
Pagepool: 20MB
Version: I8000.23518.JA5.SB05
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- Core 5.2.23518 Build 23518.5.5.0 (Windows Mobile 6.5.5 của nhóm COM5)
- .NET Compact Framework Version 3.5.9198.00
- Windows Media Player 10.3 Build 23518
- Office Mobile 2010 (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile, SharePoint Mobile)
- FlashLight
- SRS WOW HD for OMNIA II
- Soft Reset (Written by Sonblack)
- Các ứng dụng cần có của PPC như: PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9) (forget to add), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... với các version mới nhất
Basic applications for PPC such as
PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.2.3), Total Commander (v2.52 beta 2)... with their newest versions.
- Loại bỏ một số ứng dụng không cần thiết! :D
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor
Removed some unnecessary utilities! (see above list)
- Fix timebomb
- Fix Dialpad for suitable with build 23518 (not display scrollbar in dialpad)
Fix hiển thị thanh cuộn trong dialpad với build 23518
Link đã có sẵn - The links are available now
DOWNLOAD I8000 ROM 23518
(Đã có bản update hoàn chỉnh hơn, vui lòng không dùng bản này nữa)
Updated version of this ROM was available, please do not use this ROM anymore
I8000 ROM 23518 (JA5) - Part 1
I8000 ROM 23518 (JA5) - Part 2
I8000 ROM 23518 (JA5) - Part 3
Password: Sonblack
Chúc vui!
Enjoy it!
Sonblack
Đang up rom lên host, link sẽ được cập nhật từ dưới lên, đã có link số 3, 2. :D Link 1 sẽ có sau vài phút nữa!
The rom is being uploaded to host! The link 2 and 3 are available now! :D Link 1 will be finished after some minutes!
Edit: Đã đủ link - All links are available
Tốt quá bản này start và X đều chuyển xuống dưới tiện để dùng một tay rồi ^^. UP nhanh Anh Sơn ơi, em lại chuyển sang bản này ^^
Hà hà nhanh quá lại có cái để up....mới up bản base hôm qua hôm nay chuyển sang bản này thôi...cảm ơn anh Son nhiu ha...
hi, SB. thanks for the ROM. it is faster than any 6.5.x out there. thanks.
few things that I'd like to point it out, if I may.
1.the battery indicator dose not change whether u plug in charger or USB, have to tap start menu to get it work properly. it was working fine on ur 28.008.
2.the keyboard dose not automatically popup, i know there's a way to fix it by reg. editing, but i forgot. ~ X (
3.Could u please keep voice commend, it is very useful for people who drives a lot or showing it off to those iphone Fanboys, \ - /
4.the WM 7 titanium Samsung is way better than one, i love it so much on ur 28.008 and i believe a lot people that love it too. would u please to include WM 7 with all of ur future 6.5.x ROMs.
thank u
Keyboard auto popup :D, you can edit registry as follows:
Find k.e.y:
[HKEY_CURENT_USER\ControlPanel\Sip]
Edit the value following:
change "TurnOffAutoDeploy" from 1 to 0 for auto popup.
0: Keyboard auto popup.
1: Turn off keyboard auto popup.
Enjoy it!
Chưa kịp tận hưởng bản ROM SB04 đã có bản SB 05, nhanh quá hehe, cái thú up ROM sao mà khoái thế không biết. Thanks Mr Sonblack very much much...=D>
Bản ROM này vuốt chạm rất êm và nhanh, giao diện đẹp.---> Bản ROM này sài cho tết con Cọp đây, hehe. \-/=))\-/ =D>:-??=D>
Anh Sơn cho em hỏi nếu muốn update thời tiết thì phải cài thêm vào phải không?
Kô thấy CleanRAM 1.9 trong rom bác Sơn ơi :D
Cảm nhận ban đầu thấy vuốt có vẻ kô mượt = SB02 và 03
Nút X kô thoát hẳn phần mềm (bản 6.5.5 nào cũng bị hiện tượng này)
Bỏ cleanRAM để anh em tự xử :D
Vuốt không mượt là tại build
Nút X không thoát cũng tại build
Hai cái tại build thì chờ COM5 thui à! :D
Nói chung chỉ có các build 21xxx hiện tại là thích hợp nhất. Còn các build khác đều là beta, vẫn còn đang test nên một số thứ chưa hoàn chỉnh là điều đương nhiên. Mình khắc phục được cái nào thì hay cái đó thôi. Quan trọng là chúng ta được cảm nhận cái mới và một số thứ đã ổn định.
cleanRAM I want you to treat yourself :D
Touch is not smooth because of build version
X button don't operate because of build version too
Two above reasons we should wait COM5 group to develope completely :D
Generally only build 21xxx current is most appropriate. Now the others are beta build, still a test number is not complete of course. Her overcome what it does or the only. Is important that we are feeling something new and some things were stable.
the second version of 6.5.x ? haha, thats great! when would that be? \-/
You use Google Translator for translating my post. :D I revised the post by English for reading clearly.
I added CHome & Titanium Weather, Voice Command to ROM, adjusted something and r
emoved Midomi, Application Store and SPluginFavorites from original ROM JA5. If you like it, I'll update other version to our forum.
How about your opinion?
- Bản này xem Mobi TV không được ---> Streaming player báo lỗi : data time out (đã chỉnh kết nối qua internet nhưng khi xem tivi thì nó lại kết nối qua wap)
Anh chưa bao giờ dùng cái này cũng hem biết dùng sao? Ngú ngớ vậy đó! PM cho anh cách dùng, anh test và hoàn chỉnh lại luôn nha! Thanks!
haha, google dose something wrong then. but if u dont mind to upload the new ROM, i would really appreciate. and if u could take Samsung My Files out and fix the battery indicator. it'll be perfect ROM for most of us here. \-/
Mobi 3G
...! PM cho anh cách dùng, anh test và hoàn chỉnh lại luôn nha! Thanks!
Bản ROM SB04 xem mobi TV ngon lành
Em sài mạng Viettel, vào trang web : http://mobitv.vn đăng kí dịch vụ
Mình chỉ cần cài đặt cho trình duyệt Opera : internet là có thể xem tivi ( Settings - Connections -Select network: The Internet)
Bản SB05 settings ok rồi nhưng không xem được
Tốn thêm 1 cái SIM khuyến mãi Viettel về hì hục test thì ra do mạng và connect ở thời điểm đó. Ka ka, sẽ có 1 bản update chọc ghẹo bà con chơi! =))
I buy one SIM for testing MobiTV in Vietnam with Viettel Network. It's OK now!
I'll update one ROM! :D
