BuuPhucCT
Well-Known Member
RocketDial Pro (Smart Dialer) v2.6.5.1
Đây là PM hỗ trợ cho việc quay số và tìm danh bạ 1 cách nhanh nhất.
TÍNH NĂNG
RocketDial is fast and powerful Smart dialer which is the only dialer support T9 search for all fields of contacts (name,phone,email,address,notes,im,events,websites ..) , the only dialer supports changing background , the only dialer supports handwriting , the only dialer supports tab color for groups.
Detailed Features:
- Fast and Powerful Smart search T9, search for names, organizations, title, phone numbers,websites, notes... and all the information contacts have.
- Favorites support, large buttons for select, quick and easy dialing.
- Perfrect contacts support : send messages, write emails, delete your contacts in one click, everything is fast and convenient.
- Speed dialing numbers 1 - 9, press and hold the button to assign a speed dial. You can also configure the speed dial menu.
- Call Confirm, show confirmation dialog every time user placed a call, no more accidental calls.
- Perfect T9 search for groups , easily find the group through T9 search group name. support adding color for each groups tab.
- Advanced call history management, batch mode, quickly create a reminder in your calendar for the contacts and so on.
- Search Contacts simply through finger-drawings
- Perfect support for Last name first display method, support contacts order on last name.
- Supports US/Canana Area Code, show locations for incoming/outgoing calls.
- Change background , choose picture from your phone to use as dialer background.
- And many other exciting improvements .
What's in this version:
New Feature: Add call log number to existing contact
Detail Improvement: Improved contact screen, added T9 button for convenient search , add filter button to filter contacts based on events/number/nickname.... , T9 search also based on the filter.
New Feature: Add Hebrew /Georgian/Hungarian language support
New Feature: Added Background Picture Support ,(Select Image, select color...)
New Feature: added Tab Color for Group Screen.
More existing changes
http://www.mediafire.com/?6n06yls945e1gpg
UPDATE RocketDial Pro v2.8.9
http://www.pdaviet.net/showthread.p...cho-android!&p=1869534&viewfull=1#post1869534
Cập nhật RocketDial Pro v2.8.12
UPDATE RocketDial Pro v2.8.31
UPDATE RocketDial Pro 2.9.0
UPDATE RocketDial Pro v2.9.7 Build 2
UPDATE RocketDial Pro v2.9.8 Build 2
UPDATE RocketDial Pro v3.0.0
Update RocketDial Pro 3.3.1
http://www.pdaviet.net/showthread.p...-minhup-v300&p=2280738&viewfull=1#post2280738
Update RocketDial Pro Dialer&Contacts 3.3.2
http://www.pdaviet.net/showthread.p...-minhup-v331&p=2290049&viewfull=1#post2290049
UPDATE RocketDial Pro Dialer&Contacts v3.3.5
