Rom 6.5 21198 by secter
ppcboy
Rom 6.5 21198 by secter H1 & H2
Rom 6.5 của Secter bản cập nhật
- System generally runs pretty fast! Sit belts on
- New tsks: Vera Wang red, Ron Arad orange, Isaac Mizrahi purple, Rock and Republic black, Classic Blue, DVF green
- New Titanium blue sidebar! Better touch and if u have it pressed shows nice fade effect.
- New InCallRecording!
- Exchange Server works!
- Added nicer wallpaper
- Fixed FingerKeyboard keys! Looks much nicer.
- Titanium and honeycomb runs smoother than before!! I have removed the hexagons and i have used only selection hex.
- Removed Windows Update
- Removed Rhodium Finger. You can download the cab install it if u want to.
- Samsung Keyboard works!
- Big Volume control works!
- IE6 works good with flash videos, Opera works also.
- MSN Widgets (Money and Weather) works!
- Marketplace works!
- Fixed HTC Taskmanager (thanks Shokka)!
- Added .netcf3.5
- Added sztupy Favorite hackings.
- Added psShutXP.
- Added Games
- Kept Opera (v15746)
- Kept Java, FM Radio, FavoriteSettings, Internet Sharing
- Optimized files
- Almost everything is removed, cant list everything it is known what DXIA5 includes
http://www.mediafire.com/file/n4akzg14tmd/DXIA5_21198_vH1.7z
Bản H2
Changes from H1:
- Added WeatherPanel! Check screenshots.
- Fixed tsk every menu should looks kinda 3D except Windows Black (smth is wrong with it).
- Fixed with wallpaper issue.
- Fixed start menu for landscape.
- Added a faded start menu.
- Changed to the default light selection on start. I will provide cabs to match with tsks and hexagon selection.
- Removed HTC Task Manager (looked ugly). I suggest to install pBar, inlcudes also battery meter. Check screenshot.
- Added Diamong Hologram
. Just for testing the sensors hehe
. Check screenshot.
- Use the cab to enable WindowsLive tab because WeatherPanel disables it.
Known issues:
- Titanium distorts on landscape because of the WeatherPanel, the rest work normally. (i dont mind cause i use only Portait
http://rapidshare.com/files/215169540/DXIA5_21198_vH2.7z.html
