[ROM][ICS][BETA][12/25/11] Virtuous Inquisition v1.3.0 :: Senseless ICS (4.0.1)
ntt2006
[ROM][ICS][BETA][12/30/11] Virtuous Inquisition v1.4.0 :: Senseless ICS (4.0.1)
Changelog
v1.4.0 (12/30/2011) [STABLE]
  • Wipe required coming from 1.3.0, due to all the changes.
  • Replaced all AOSP apks with those from my own from-source 4.0.1 build.
  • Eliminated effectively all Sense apks with the exception of Camera, FM Radio and Flashlight. Framework obviously remains. (Original Sense ROM had 206 apks, Inquisition only has 84).
  • Replaced Stock ICS launcher with Nova Launcher, which is an enhanced ICS launcher. Much faster with a lot more functionality.
  • Disabled Virtuous OC daemon. Forcing CPU1 online degrades performance. Let mpdecision deal with this automatically.
  • Removed Music application, as it was redundant with Google Music, which can play local media without access to the service.
  • Updated AOSP theme (Full/v4) again. (Thanks: Shnizlon)
  • Added WiFi router app which should resolve the tethering issues.
  • Added Facebook, Twitter and Adobe Flash as user apps.
  • Disabled Fastboot.
  • Many of the same nagging issues remain but the ROM is substantially more responsive.
v1.3.0 (12/25/2011)
  • Full wipe required, sorry guys. This is why it's beta.
  • Fixed mobile data being off after initial boot.
  • Enabled WiFi automatically on first boot.
  • Disabled power manager from ever being triggered.
  • Disabled quiet-on-pickup, which is a Sense feature.
  • Disabled pocket mode, which is a Sense feature.
  • Eliminated adb notification icon.
  • Updated AOSP theme (v8). (Thanks: Shnizlon)
  • Added Titanium Backup as a user app.
  • Added Quick Boot as a user app. Use this for booting into bootloader, recovery, etc.
  • Switched default wallpaper to an ICS live wallpaper.
  • Added /system/etc/pre-init.d, which works similar init.d, except that scripts are executed prior to starting the Android java stack.
Download ROM v1.4.0
(MD5:3168861cfe39c787ec0c1e0ee0c1dcb5)
vo5UmC.qrcode
Download ROM v1.3.0
(MD5:f50b2fff25778992f7cfaf809091ad82)
sJCOj0.qrcode
Link gốc XDA
BẢn này xài quá chán, trưa nay mình thấy hay thử up nhưng hầu hết các ứng dụng cài thêm vào đề bị FC mà bản này chưa được root, quay về 2.35 chờ update fix vậy ! chán ....
Updated v2.0
Full wipe required from all prior releases.
Matching firmware package is required.
Upgraded base to HTC TEST 3.12.401.102.
Integrated AOSP components from new 4.0.3 build from source.
Reapplied all the changes/fixes from prior versions of the ROM.
Upgraded Nova to beta9.
Using stock kernel, SebastianFM's 4.0.3 1.5GHz kernel was unstable for me. You can flash it on your own, if desired.
Modified Nova's default home button behavior to mimic pure AOSP.
Upgraded Market apps to the latest versions.
Moved almost all Market-available apps to /data/app.
Added WiFi calling support for TMOUS users; needs testing. (Thanks mike1986).
link firmware : http://www.multiupload.com/DC3MXCA1ZD
link: http://www.multiupload.com/LR9YZ1LQIA
v2.0.1 (1/10/2010) [LATEST STABLE]
Wipe should not be required. However, if you have issues, wiping will be the first recommendation.
Fixed Calendar syncing and event adding
Fixed Face Lock.
Fixed signal bars and blurry icons by switching to Sense notifications (trust me on this).
Fixed "acore" FC when adding Google accounts.
Upgraded Nova Launcher to beta10.
Upgraded to AOSP theme to Shnizlon's latest version.
link : http://www.multiupload.com/GWNBCDYP3M
