ntt2006
[ROM][ICS] | March 7| Energy™ -.¸¸.·´¯ Sense 3.6 ROMs Themed ¯´·.¸¸. -
- Rosie 5x5 Layout and half transparency
- Transparent and extended quick settings
- Blue highlights instead of green
- Deodexed, zipaligned, tweaked
- Improved SD card read ahead
- Busybox + runparts, TitaniumBackup
- A few HTC Apps removed, like HTC Navigation
- A lot of other bloat removed
- Stock HTC Kernel
- Screenshot by pressing Power and Home
- Advanced Power Menu
- Updated hosts file for ad removal
- Fast... Stable.. and GREAT battery life !
- Based on the latest OTA 3.32 release !
- Tweaks!
Screenshots
Changelog
Changelog
YÊU CẦU CÀI ĐẶT FIRMWARE PHÙ HỢP TRƯỚC KHI CÀI ĐẶT ROMMarch 7th, 2012 (ICS)
FIRMWARE 3.32
March 6th, 2012 (ICS)
- Updated to 3.32 base (final)
- Updated ROM graphics
- Included Tweaks !
- Beats included.
- New volume sounds
- New stuff all around.. check it out.
- APM mod included.
FIRMWARE 3.32
February 29th, 2012 (2.29.2012)(ICS)
- Included Tweaks !
- Beats included.
- New volume sounds
FIRMWARE 3.30
February 20th, 2012 (2.20.2012)(ICS) FIRMWARE 3.24
- Updated to 3.30 base (release candidate.. more stable)
- Included Tweaks !
- Autobrightness fixed.
- Flash the 3.30 firmware for it
[*=center]Major stability update please upgrade
[*=center]Fixed su issues with "nobody" asking for permissions
[*=center]Sense FCs should be gone
[*=center]Corrected an "out of memory" issue with bitmap rendering in htc resources
[*=center]Made some graphics in the keyboard that were green... blue
[*=center]Dialer graphics changes (thanks to vin for the graphics!)
[*=center]Increased speaker volume a bit more
[*=center]GoogleTTS replaced for less distortion in google nav (thanks to dfwcomputer)
[*=center]Adjusted dalvik vm heapsize
[*=center]build props cleanups
[*=center]Added mudhi's modified music app for more effect options (beats, eq, srs, dolby)
[*=center]Fixed sense battery widget, now text is black on white, also blue graphics...
[*=center]Lots of framework graphics changes again
[*=center]Sense 4.0 ringtones/alarms/notifications from the HTC Endevour
