[ROM][★Sense 3.5★][12 Jan]RCMix 3.5 v7.0 ( Nhanh và mượt )
LinhKu
-Mình đã test bản rom này và cảm thấy cũng rất ổn,mọi người ai thích thì test cùng nhé :p
SCREENS:
Changelog:
v7.0 dont complain about low build number anymore! hehe
Cleaned it a bit from some unneeded jpgs and apps (OTA and some other upgrade apps etc.)
Uppdated the market apps (maps, flashplayer, youtube etc.)
Resized Bootanimation, all bootanimations in tweaks are also resized, they look very nice now BigT did a very nice job!
Added one new Bootanimation to the Tweaks.
Removed Downanimation, have problems with resizing it... can be downloaded in Tweaks.
Added 4EXT touch recovery 1.0.3 beta8
Added 4EXT recoveryUpdater app (you can flash roms, fix permissions, make backups... + much more
Modded music app, now you have SRS, Equalizer and BEATS available, both on Headphones and speaker. Thx sbryan12144 for that.
Updated Beats
Removed the beatsnotify, didnt play well with the modded music app... you turn on/off beats in music app menu.
Laputa navigation should be fixed
Pattern lockscreen fixed
Playing video in landscape mode is ok now
Weather animation proper sized now
Mail does not trunkate 2/3 raws preview
Proper sized icons on homescreen
Updated Sony BRAVIA Engine
Paginated view in drawer has no ugly divider anymore.
Added original framework, which fixed sms/mail Return to dock mode issue and rotation animation, but broked 1080p recording, only 720p available. I have added the modded framework, as an option when you flash the rom.
Added possibility to choose 1.2GHz stock kernel or modded by sebastianFM 1.5GHz GPU 300MHz
Added possibility to choose original Bliss QuickLaunchwidget when you flash the rom. Be aware that the widget need a Bliss fusion.apk, so use it with Bliss Rosie. With Bliss fusion, stock Rosie will be transparent, so if you want to use stock Rosie again, you will either need to push the fusion from /system/app from this zip, or flash the rom without wipe and dont choose bliss
- link download : http://rom.robocik.mobi/Sensation/RCMix3.5/v7.0/
uplates: Changelog:
v7.1
no need to choose if you want the 720 or 1080p fix while flashing, we just needed that for 1080p recording, since m0narx modded the stock camera, the patch is not needed anymore now we have everything working as it should.
probably fixed the camera freeze
hopefully fixed the wifi calling
added amaze camera as a choice when flashing the rom
Fixed stock widget
Updated some market apps
Moved 4EXT updater to data, so it can be uninstalled if needed.
link:
http://rom.robocik.mobi/Sensation/RCMix3.5/v7.1/
-Up rom qua recovery và full wipe trước khi up
- Radio phù hợp : http://www.mediafire.com/?a86en1h6p8bzw65
em thì có cảm tình với RCmix từ hồi ở Desire HD rồi,dùng bản này có vẻ không vất vả so với mấy bản android 4.0 :ar!
bản này dùng rất là oke, mọi thứ đều mượt và chưa thấy phát sinh lỗi gì. Để test thêm
Mà bản này khi flash ko có market thì phải , mình phải tự dow MK về
thanks chủ thớt
thanks chủ thớt
flash rom xong có market luôn mà bạn,đâu cần phải cài nữa đâu,lạ nhỉ
uplates: Changelog:
v7.1
Fixed stock widget
link: http://rom.robocik.mobi/Sensation/RCMix3.5/v7.1/
đã test cũng ok. trong các bản game thì game SHotgun chơi lại rất lag, và treo luôn, còn phiên bản cũ thì ko bị. e, đành quya về ! hix
Về khoản game thì anh ít test lắm nên không rõ.
dùng ct nào để kt 2 cpu có hoạt động ko nhỉ ? sao máy em 1 con chạy . 1 con offline. kỳ vậy ta ?
Đa phần thì các bản rom chỉ thấy 1 cpu chạy thôi em, nếu muốn dual thì em cài phần mềm super turner pro mà anh có post trong các bài trước, hình như trong topic insertcoid.
