[ROM] Sense-o-Maniac - ICE 4.0.3 v1.9 Sense3.6
huybinh_dnpt
ROM Mar.18 Sense-o-Maniac - ICE 4.0.3 - Sense 3.6 - v2.0
Sau khi dùng thử các bản trên PdaViệt thấy khá tốt nhưng vẫn còn một số lỗi. Mình check trên XDA có bản rom này Sense-o-Maniac - ICE 4.0.3 v1.9 Sense3.6 này khá hay, các iocn khá đẹp, có nhêìu tuỳ chỉnh cho các bạn tự chọn , chơi game ko thấy lag và nóng máy, thời gian dùng pin cũng rất tốt.
Sense-o-Maniac - ICE Sense 3.6 v2.0
Added Muhdi Beats port - Sounds better in my opinion
Update SuperSU to v0.83
Added 1,6Ghz, 1.7Ghz & 1.8Ghz kernel by SebastianFM
Added md4.ko for full cifs support
Adreno 2xx GPU Binaries updated for ICE (Read more here)
Added stock SystemUI without EQS as default
Added EQS with Leedroid tweaks as optional in the installer
Android 4.0.3 - 3.32.401.105
HTC stock kernel @ 1.2Ghz
HTC stock kernel @ 1.5Ghz - by SebastianFM - Optional
Advanced Power Menu (a big thx to CapyChimp to pull this masterpiece off)
HTC Stock Camera
HTC IME Trace
No Recent Apps - Optional
5x5 App Drawer - Transparant background with no text- Optional
Beats audio
Sony Bravia Engine - Optional
Speed & RAM Scripts
Zipaligned on every boot for speed
Disabled HTC Snooping
Speed optimization scripts
init.d support
Face unlock
Multi language
Rooted and added latest SU
ES File Explorer - Optional
Unsecured boot.img
Tweaked for speed & memory improvement
Fully Zipaligned
Fully de-odexed
init.d scripts
EXT 4
Restore packages are available in the interactive user installer (Your choice what you want)
WiFi Calling Support for US Tmous users
Extended QuickSettings (Thx J4n87)
Aroma Installer (Thx Amarullz) 1st Sensation rom with Aroma Installer
Virtuous Rom Optimization (Thx Virtuous Team)
Cifs Support
Volume Wakeup Key - Thx Max128 - Optional
TMous Support (Don't know if it works on the new base)
Native Screenhot - (PowerMenu + Home)
Removed optional Beats from the installer - it's in the base now
Google Play StoreMore to come
SuperSU v0.73 as optional - beware Chainfire build it from scratch so bug expected
Adobe Flashplayer to v11.1.115.7
4EXT Recovery Updater to v2.2.8
4EXT Touch Recovery to v1.0.0.4 RC1
Google Maps to v6.4.0
Leedroid Tweaks v4 Lite
[video=youtube;x_nWKVi0m-4]http://www.youtube.com/watch?v=x_nWKVi0m-4&feature=player_embedded#![/video]
Linkdown load
dev-host.org/2uH
http://uploaded.to/folder/lkj7ni
Bạn ơi cho xin cái link ghi rõ nguồn để mọi người cùng theo dõi và thưởng thức những bản tiếp theo nhé!
Mình đã thử nhiều Rom chạy ICE 4.0.3 -sense 4.0 rồi nhưng bản Rom này có update thêm nhiều phần mềm mới mà sense 4.0 chưa có:
- Google Play 3.4.7
- SuperSU v0.73 as optional - beware Chainfire build it from scratch so bug expected
- Adobe Flashplayer to v11.1.115.7
- 4EXT Recovery Updater to v2.2.8
- 4EXT Touch Recovery to v1.0.0.4 RC1
- Aroma install binary to v1.63
- Google Maps to v6.4.0
- Leedroid Tweaks v4 Lite
rom này mình bị lỗi là khi đã xóa hết các trang màn hình đi rồi (mình để 1 trang thôi), khi restart lại thì lại nguyên 7 trang.
cho em hỏi cái này đừng chê em ngu nhưng hình như 4.0 k cài đc app ngoài market đúng k các bác
Khi up rom xong bạn vào bảo mật ... tích vào ô cho phép cài đặt ưng dụng ngoài maket là ok ...
Mình cũng dùng thử một số ROM sense 4.0 nhưng thấy còn khá nhiều lỗi. khó chịu nhất là độ phân giải chưa tương thích (bàn phím và ứng dụng weather)
ngoài ra máy chạy cũng khá chậm, hiệu ứng chuyển bị giật có lẽ phải chờ thêm thời gian nữa các bản sense 4 mới hoàn thiện được.
Bản Rom này Sến 3.6 mờ ? tại sao thằng HTC lại không cho SEN XE lên sense 4.0 nhỉ ? chê hôi ah ?
