ROM TNT series cho TyTN_II
NhatToai
Super V.I.P
http://rapidshare.com/files/108122767/TNT.19202_Official_Kaiser.rar.Trên đây là link của bản ROM TNT OFFICIAL mà mình đang xài.Mình thấy nó chạy rất ổn định mặc dù cài rất nhiều ứng dụng.Chẳng dấu gì trong gần một tháng qua mình đã up khoảng 30 bản khác nhau và giờ thì mình thấy rất thoải mái và yên tâm.Mình đã thử cài gần 40 ứng dụng mà nó vãn bình thường cả về tốc độ lẫn sự ổn định.Thanks to TNT Series.
bản rom Pro 32Mb PagePool
Mã:
http://rapidshare.com/files/113848627/TNT.19202_Professional-Kaiser-32PP.rar
Adobe_2_00_288531_PPC _to run pdf files
AdobeFlashLite_2_1 _to run flash files
Advanced_Config_Tool_2_1_0_0 _edit your device settings as you want
AltTab_1_0_1_0
Bluetooh_Audio _send audio to your BT headset
BtCrawler_1_1 _search in details for other BT devices
btIO_0_6 _useful BT controller
Call2Contact_1_0 _to remind you about saving any new number after the call ended
CallFirewall_1_4 _block calls and sms
CHM_ebook_Reader_2 eBook reader
ClearTemp_1_0 _clear your memory from temp and bad files and registries
Dr_yar_1_6 _unbleivable bt app, it can receive while the device is switched off.../ double click to run
Battery_status indicator (it is a colored bar upper any screen)
EventCountdown_1_0
FDCSoft_Tsk_mngr_2_9_0_1
nice Games (Hearts/Battleship/BSoduko1_4/Dekses/Dots/minesweeperppc/Snake)
GPSTool
GroupSMS_1_4_3 _send SMS's to specified groups
GSFinder_0_1 _powerful explorer
HTC_RSSHub_1_0_0_7
HushSMS_0_3
LCMinutes_1_44 _let it save your calls/sms/GPRS... costs
MobileJustice_1_0_1
notepad
PeekPocket_1_4 _good wifi tool
TCMP player .71 edited (tnx milesmowbray)
Video dll and registry which fully support youtube as your PC (integrated with TCMP)
Pocket_rar_3_71
Pocket_Screen_Capture
PocketCryptex_1_1
RealPlayer
Redial_1_02 _vibrate the device when the other side answered
SMS_Backup_1_1
SoftKeyAppEx _change today buttons
SoftReset
VIP_RingTone_5_5 _set ringtones for contacts and groups in one click
WinXplore_0_5 _powerful tool for managing startup folder/remove/move... and all windows folders
NOTES:
- This rom is compatible with 1.65.14.06 radio only, it is included with the rom.
- changing radio version may effect on GPS/Camera/Calling/BT...
- some edits in xip was applied using some new xip from 19209 build.
- you have to read wiki and sticky threads before flashing (unlock your device)
Some Apps Informations:
** Dr.YAR 1.6 bluetooth:
many features, like:
- show bluetooth sender name.
- choose a location for files recieved.
- recieve when the device off.
- don't delete MS bluetooth, you can recive from both.
- ... MANY means MANY
if you want to use it, you find an icon on the tray, double click on it.
note: there is a white window if you recieve just hide it then open it again.
(very useful)
» Call Firewall
• Summary: CallFirewall basically rejects unwanted calls. Features & Options: a. Accecpt all calls - pretty self explainatory b. Accept call from My Contacts only - accepts calls from contacts only, others are rejected c. R...
» Group SMS
Summary: Group SMS Solution. As the name suggest it is basically a program to send SMSes to a group of people at the same time. Following are the features: - Category Wise Contact Pickup. - Individual Contact Pickup made easy.
» Event Countdown v1.0
• Summary: From counting down to a movie event, to every day reminders to cooking a dinner. Event Countdown lets you add up to 200 events on your Pocket PC. You can countdown to a particular date or countdown from a se...
ClearTemp
• Summary: ClearTemp is an application for you to clear temporary/unused files and unused registry keys/values on your system easily. It also allows you to clear your Recent Program List, Internet Address History and b...
WinXplore
• Summary:WinXplore is a simple tool that allows you to manage certain folders under "\Windows\" in a quick and convenient way. Usage Notes:
- Select a Folder from the dropdown menu to navigate to a certain folder.
- Tap & hold in the listbox to add/delete a file from the folder.
Pictures:
