TP.HCM SamSung Galaxy Note 2 Sửa Lỗi Mất Sóng Ok !
Taki7610
Unlock_GSM
Mã:
Welcome to Octoplus/Octopus Box Samsung software version 1.3.6
To connect SC-04E phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Builds numbers" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options->About Device.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Close window.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
To connect GT-N7100 phone you have to perform the following steps:
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Go to dial window.
10. Enter "*#7284#" number.
11. Set "UART" radio button to "MODEM" value.
12. Set "USB" radio button to "PDA" value
13. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM10
Selected model: GT-N7100
Reading info, please wait...
Detected phone model: GT-N7100
Firmware compiled date: Wed Mar 27 10:38:43 KST 2013
Phone SN: RF1C9ALEWLF
Android version: 4.1.2 (JZO54K)
Checking Root:
Phone is Rooted.
Repairing network. Please wait, it can take some time...
Phone will restart now
Network is successfully repaired.
