Taki7610
Unlock_GSM
![](http://i988.photobucket.com/albums/af7/luanhongha/ScreenHunter_002_zpsa0276bf1.jpg)
Mã:
Welcome to Octoplus/Octopus Box Samsung software version 1.5.5
To connect GT-I9190 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM252
Selected model: GT-I9190
Mode: Emergency
Unlock for GT-I9190 phone in emergency mode can’t be done
Selected port: COM253
Mode: Normal
Phone model: GT-I9190
Firmware compiled date: Jun 28 2013
Firmware compiled time: 00:00:00
Firmware released date: Nov 11 2013
Firmware released time: 19:28:53
Phone IMEI: 357962-05-455792-1
SW version: M8930B-AAAATAZM-3.2.27040
Unlocking phone...
Creating NVM backup
Reading NVM done!
ADB server killed.
Firmware compiled date: Mon Nov 11 18:19:38 KST 2013
PDA version: I9190DXUAMK2
CSC version: I9190OLBAMK3
SW version: I9190DXUAMK2
Phone IMEI: 357962054557921
Phone SN: RV1D71HGFMP
Android version: 4.2.2 (JDQ39)
Cheking Root
Can't root Android version 4.2.2 and higer. Please Root the phone, or flash phone using firmware with lower version of Android or rooted firmware and repeat operation.
Can't get root privileges.
Phone is not rooted
Phone unlocking failed
Mode: Normal
Unlocking phone...
Creating NVM backup
Reading NVM done!
Cheking Root
Phone is not rooted
Mode: Normal
Unlocking phone...
Creating NVM backup
Reading NVM done!
ADB server killed.
Cheking Root
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-GT-I9190-357962054557921-21-05-2014_14-32-25-.asec file
Deactivating MSL...
MSL deactivate successfully
Phone will restart now. Please don't disconnect cable!
Incorrect IMEI
Found phone on COM253
Repairing NVM for GT-I9190 phone...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
