TP.HCM SamSung SC-O2B Unlock Ok !
Taki7610
Unlock_GSM
Mã:
Welcome to Octoplus/Octopus Box Samsung software version 1.3.4
To connect GT-I9300 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in software.
To connect SC-02B phone you have to perform the following steps:
2. Go to Menu->Settings->Applications->Development.
4. When the message appears press "Yes".
5. Connect USB cable to the phone.
6. Press "Read Info" in software.
Selected firmware file: SC02BOMJJ1.oct
Please switch your phone to the download mode and connect it to a PC.
To put SC-02B phone into download mode you have to perform the following steps:
1. Reconnect phone battery.
2. Press and hold "Volume - "  + "Home" + "Power" buttons.
3. When phone turns on press "Volume+" button.
Found phone on
Firmware write started.
Writing KERNEL section...
KERNEL section has been written successfully.
Writing PARAM section...
PARAM section has been written successfully.
Writing DBDATAFS section...
DBDATAFS section has been written successfully.
Writing FACTORYFS section...
FACTORYFS section has been written successfully.
Writing CACHE section...
CACHE section has been written successfully.
Writing MODEM section...
MODEM section has been written successfully.
Firmware writing successfully completed.
Platform: Samsung Android
Selected port: COM10
Selected model: SC-02B
Mode: Emergency
Unlock for SC-02B phone in emergency mode can’t be done
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM60
Detected phone model: SC-02B
HW Version: SGH-N013HKNDCM
Phone IMEI: 353975-04-335379-2
ADB server killed.
Firmware compiled date: 2010. 10. 13. (수) 06:06:41 KST
Phone IMEI: 353975043353792
Android version: 2.2 (FROYO)
Selected port: COM60
Unlocking phone...
Device will be rooted now. This process can take about 2 minutes. Please, wait...
Root privileges successfully obtained.
Unlocking phone. It can take some time. Please wait...
Providing modem backup...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\MDM-SC-02B-353975043353792-23-09-2013_15-25-02-.oct file
Switching to emergency mode...
Found phone on
Writing unlock patch...
Phone is successfully unlocked
----TV :D
Mã:
<ID:0/025> Added!!
<ID:0/025> Odin v.3 engine (ID:25)..
<ID:0/025> File analysis..
<ID:0/025> SetupConnection..
<ID:0/025> Initialzation..
<ID:0/025> Get PIT for mapping..
<ID:0/025> Firmware update start..
<ID:0/025> boot.bin
<ID:0/025> NAND Write Start!!
<ID:0/025> cache.rfs
<ID:0/025> factoryfs.rfs
<ID:0/025> modem.bin
<ID:0/025> param.lfs
<ID:0/025> Sbl.bin
<ID:0/025> zImage
<ID:0/025> RQT_CLOSE !!
<ID:0/025> RES OK !!
<ID:0/025> Completed..
<OSM> All threads completed. (succeed 1 / failed 0)
<ID:0/025> Removed!!
<ID:0/058> Added!!
<ID:0/058> Removed!!
