SISContents v1.65 Build63{Tool for unpack, edit and sign Symbian 9 SIS packages}28/10
ngviethoa
SISContents - Unpacking, editing and signing of Symbian SIS packages
SISContents is a tool that allows you to unpack, edit and sign Symbian 9 SIS packages (Nokia S60 3rd, 5th Edition and Sony Ericsson UIQ 3.x platforms are supported). It helps you to inspect the files contained in SIS package, to see certificates against which it was signed as well as to view the PKG script that describes the on-device installation process. You can also edit the contents of packages and sign them after that.
Main features of SISContents:
* - read the contents and show information on SIS packages;
* - unpack files from SIS packages;
* - extract embedded components of packages as sis files (including certificates and signatures);
* - view and save installation PKG script;
* - sign packages, show information on certificates (validity period, issuer, subject, etc.), and delete them from package;
* - edit package: modification of name, vendor, version, type of installation, supported platforms (devices), software dependencies, options is available. You can also add, replace and delete files/components containing in a package and change capabilities, UID3, SID of executables (i.e. exe, dll, ldd, etc.);
* - read the contents and unpack files from N-Gage packages;
* - extract and edit contents of mif files embedded in sis packages;
* - view, extract images from and edit multibitmap (mbm) files embedded in sis packages;
* - modify themes for S60 platform.
Compatibility: Windows XP/2003 Server/Vista/2008 Server/Windows 7
Change log:-Latest version: 1.65 Build 63
* Added ability to manually edit installation folder of Themes;
* Added ability to search the database elements in the editing window of skn element properties;
* Ability to view content of language resources (RSC);
* Added Spanish language;
* Fixed bugs of previous version.
DOWNLOAD
http://www.fileserve.com/file/QNUbJ8C
Topic mới là những phần mềm mới, hay. Nội dung phải được giới thiệu bằng tiếng Việt....
Cái này cũng đã được shentran cập nhật trong topic ở dưới bạn à!
em định dùng thử gu gồ trans nhưng sợ nội dung dịch ra chuối wa nên để nguyên eng.như vậy là phải để vie hả bác.lâu k pót bài.sr ^^!
