[SOLVED] SamSung S3 SGH-I747 Up OTA 4.3 Treo convert T999 Fix Unlock Ok !
Taki7610
Unlock_GSM
[SOLVED] SamSung S3 SGH-I747 Up OTA 4.3 Treo Fix Ok !
1. Máy ở version 4.3 OTA mất boot do hạ firmware 4.2.1.
- Repair bằng box Easy-Jtag
Mã:
EasyJtag Suite ver.: 1.0.99.0 started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition.
Successefuly connected to box on COM520
Box S/N: 0600F00300B5F780, ,FW Ver.: 01.48
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AAF0-F1F9 , ver: 22
Loading repair file: 'C:\Users\Administrator\Downloads\Samsung SGH-i747.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: SCH-I747, Ver.: 1.00
Error loading information!
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
For support and updates visit http://easy-jtag.com
Initialising: SAMSUNG SCH-I747 Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: 0600F00300B5F780 ,FW Ver.: 01.48
Connecting to Target...
JTAG device: MSM8960.
CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4
CPU Manufacturer: Samsung , CPU Name: ARM7GEN
CPU IDCODE : 0x706B50E1 Mfg.: 0x070, Part: 0x06b5, Ver.: 0x7
CPU Manufacturer: QUALCOMM , CPU Name: MSM8960 Rev 0.7
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000011 Name : 016G92 Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00000011 Name : 016G92 Size : 4.0 M , (8192) Blocks
eMMC flash device(s) found, Device ID : 0x00110000
NAND Writing GPT, PIT, MD5...
eMMC Write OK! Elapsed time: 17.467999s (234.486 KiB/s)
NAND Writing SBL1...
eMMC Write OK! Elapsed time: 1.195069s (107.107 KiB/s)
NAND Writing SBL2...
eMMC Write OK! Elapsed time: 2.080119s (123.070 KiB/s)
NAND Writing SBL3...
eMMC Write OK! Elapsed time: 4.431254s (115.543 KiB/s)
NAND Writing ABOOT...
eMMC Write OK! Elapsed time: 15.523888s (131.926 KiB/s)
NAND Writing RPM...
eMMC Write OK! Elapsed time: 3.083176s (166.063 KiB/s)
NAND Writing TZ...
eMMC Write OK! Elapsed time: 3.446198s (148.570 KiB/s)
All Done.
- Máy lên nhưng vẫn treo do không đồng bộ với bootloader của version 4.3. Nạp tiếp openrecovery-twrp-2.6.3.1-d2att
- Nạp tiếp rom cook T999 9 Bản này mới repair imei được :D ) - Nạp tiếp modem_CWM_I747UCUEMJB.zip để có baseband và imei . Nếu nạp rồi chỉ có baseband ko có imei dùng tiếp box Octopus để repair imei ( Mìh thì bị mất imei nên phải dùng box repair) .
- Cuối cùng là xong.
